Author Topic: Converting MSD to Chrome Box question  (Read 1443 times)
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« on: December 25, 2008 - 03:49:19 AM »
We have been having issues with the ignition on a 440 in my Dart.  I am planning to convert a full MSD ignition over to the Mopar chrome box but still retain the MSD distributor and coil, but I cannot figure out which ballast resistor to use.  Has anyone tried this before?
nivvy
Re: Converting MSD to Chrome Box question
« Reply #1 on: December 25, 2008 - 04:50:22 AM »
dont need a ballast resistor with msd ignition... edit i just saw your going the other way....  :misbehaving:
Offline Jacksboys
« Reply #2 on: December 25, 2008 - 02:24:04 PM »
I was doing some reading and someone suggested using the .25 ohm resistor, but they were using the MP distributor.  Would this be the same for the MSD distributor and coil?
« Reply #3 on: December 25, 2008 - 02:39:04 PM »
the MSD coil requires a low Ohm ballast resisitor .75 or less when not being fired by a MSD ign box
Offline Jacksboys
« Reply #4 on: December 25, 2008 - 02:52:13 PM »
Sweet.
If I looked it up correctly MP has a .50 and .25 resistor, which one would you suggest?
« Reply #5 on: December 25, 2008 - 02:57:19 PM »
.5 ohm
Offline Jacksboys
« Reply #6 on: December 25, 2008 - 03:12:07 PM »
I guess I was misinformed about the .50 resistor because I cannot find it for sale, but I do see that everyone is selling the .25 resistor.  Do you think this would be too low?
« Reply #7 on: December 25, 2008 - 05:58:01 PM »
Should work fine
Offline Jacksboys
« Reply #8 on: December 25, 2008 - 10:30:48 PM »
Thanks for the help  :2thumbs:
