Hey guys, talked to the shop today and I told them I was going 4.30 C&P. After looking at my old invoices my rear end 3rd member has 29 spline axles, not a problem, I will purchase new 30 spline axles to suit my new Detroit TrueTrac posi but I am stuck. Randy's Ring & Pinion have 2 available 30 spline axles for E-Bodies and instead of taking the car in and removing one I thought I would ask. See links below, 1st link states E-Body measuring 28"-32" and the other link also states E-Body but 30" axle, what one do I need/have (stock Chrysler 8-3/4" differential).
My thoughts are they could be 'Cuda and Challenger as the 'Cuda was 2" wider, but I doubt they added length to the 'Cudas axles, etc, way too much effort, time and money for Chrysler to do that back then. Any help is much appreciated. Also, while I'm at it, what length rear wheel studs do our cars have, I basically need confirmation. I'm 90% sure they are RH Thread. Year One states them for E-Bodies as: "RH wheel studs 1/2"-20 x 1-19/32" with .673" knurl diameter. Correct for RH side but will work on LH." This is what I got last time, this is correct, yes?
Thanks guys,
Carl
http://www.ringpinion.com/ProductDetails.aspx?ProdID=5641http://www.ringpinion.com/ProductDetails.aspx?ProdID=5640Ps: Some photos I took today............
