Tach installation/set-up question
Author Topic: Tach installation/set-up question  (Read 679 times)
Offline OzCuda
« on: December 28, 2008 - 06:53:50 AM »
I have one of the VDO reproduction tacho's that fit into the spare instrument location on the non-rallye dash.  I am going to fit the gauge, run the wires etc but have a question about the settings on the back - it has a bank of 3 little switches and wanted to make sure they are in the correct location before re-nstalling the dash.  At the moment 1 & 2 are selected on and 3 is off.  Tacho is going on a 383/auto.  See the pics for what I'm talking about.
Also, what amperage is 18 guage wire (as per Mopar gauge instructions)?  Thanks.
'70 Barracuda
Re: Tach installation/set-up question
« Reply #1 on: December 28, 2008 - 01:38:30 PM »
I wish I could help , no instruction with the guage ?
my guess is ti would be for cylinder selection 4-6-8
the last time I worked with VDO guages was about 10 yeras ago
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #2 on: December 28, 2008 - 03:54:41 PM »
will this help?
http://www.egauges.com/pdf/vdo/0-515-012-044.pdf
http://www.egauges.com/pdf/vdo/0-515-010-516.pdf
Looks like #2 & #3 ARE SET TO ON AND #1 IS SET TO OFF For a V8.
Go Fast & Have Fun...
Offline OzCuda
« Reply #3 on: December 28, 2008 - 06:25:18 PM »
Thanks Dodgeboys/Chryco - looks like the first .pdf is the correct one but I might double check with some of the numbers off the side of the gauge.  Interesting that the switch settings is different for the two different gauges - I would have thought manufacturers would try and standardise this? 1 & 2 on and 3 off for 8 cyl with coil on the first .pdf.
Didn't think to search for manufacturers instructions  - isn't the internet wonderful  :clapping:
'70 Barracuda
