Author Topic: 1970 Power Steering Column?  (Read 3254 times)
Offline 422STROKER
  • Member Since 6/3/06
« on: December 28, 2008 - 03:16:20 PM »
How can I verify an E-body Power Steering Column?  Is there a spec on the length and are there any numbers on the column?
I think I grabbed a 70 E-body column PS, but want to double check it.  The lower housing does rotate AFAIKT.
Tom :1zhelp:
Tom
Offline 422STROKER
Re: 1970 Power Steering Column?
« Reply #1 on: December 29, 2008 - 07:30:51 AM »
Well it looks like it is one, I got 12" of Steering Shaft exposed outside of the housing and that measures the same as my PS column in my 72.  I hope that's right.
Tom :dunno:
Tom
« Reply #2 on: December 29, 2008 - 12:49:51 PM »
Gee, what a quiet thread this is.   :screwy:
Tom,
  The exposed part of my shaft is 12" if you include that big knuckle on the end.   :thumbsup:
Offline dutch
« Reply #3 on: December 29, 2008 - 01:54:37 PM »
hey Mike...,
you`d better adjust some lyrics here..... :22yikes:...... when April sees this....... :scared: :scared: :scared:  :smilielol:
Bart
*** Bart ***
« Reply #4 on: December 29, 2008 - 04:03:31 PM »
hey Mike...,
Bart
You know what?
I thought the same thing before I posted.   :grinyes:  Aww, what the heck.
Offline 422STROKER
« Reply #5 on: December 29, 2008 - 04:30:20 PM »
Thanks Mike, So 12" looks good?  I did word it specifically to say steering shaft for that reason.LOL
How much longer are the Manual Shafts?
Tom :2thumbs:
Tom
« Reply #6 on: December 31, 2008 - 01:14:00 AM »
somewhere in the 3-4" longer range
Offline 422STROKER
« Reply #7 on: December 31, 2008 - 01:19:08 AM »
 Thanks Chryco, looks like I grabbed the right one then.
Tom :2thumbs:
Tom
« Reply #8 on: December 31, 2008 - 01:21:25 AM »
I can go back out to the garage & mearsue mine if you want me to
Offline 422STROKER
« Reply #9 on: December 31, 2008 - 01:22:25 AM »
It would be good reference for everyone.
Tom
I can try and get some photos of mine up too.
Tom
« Reply #10 on: December 31, 2008 - 01:32:57 AM »
well this should confuse you from the bottom of the outer housing to the Top of the knuckle is 12"
from the botton of the interlock shaft to the top of the knuckle is 12.5"
& from the bottom of the outer housing to the bottomk of the knuckle is 15.5"
Offline 422STROKER
« Reply #11 on: December 31, 2008 - 01:44:11 AM »
yes I'm confused.lol
When you say knuckle?  Yours is in the car right?
Tom
Tom
« Reply #12 on: December 31, 2008 - 01:57:32 AM »
Uhh no , the car body is in the body shop being painted Purple , the K frame is sitting on the floor as I just stripped all the steering linkage & box off it & the column is on the shelf
Offline 422STROKER
« Reply #13 on: December 31, 2008 - 08:35:38 AM »
Ok, sorry about that.  This is what I got.  I'm guessing the knuckle is the coupler and yours is still attached to the shaft.
The blurry one shows a "6" on the housing, I hear that the "6" was used for 70's? and a "6o" was used on 71-4's?
Tom
« Last Edit: December 31, 2008 - 08:37:47 AM by 72challorange »
Tom
« Reply #14 on: December 31, 2008 - 10:41:05 AM »
That is shorter than mine
