Author Topic: New paint protection  (Read 1139 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: December 28, 2008 - 04:27:00 PM »
As you may have seen my car was painted recently and is now home.  I have a new cover to protect it (California Car Covers) and there was a note in the box that said that if the paint was less than 6mo old, to contact your painter.  I did and didn't get a good clear answer, I suspect he didn't know all the ramifications.  I'd like to put the cover on, but don't want to damage the paint until it is fully cured.
Also, at some point I'd like to give it a coat of wax for protection. Since I'm starting from scratch and want to keep the shiny glow for as long as possible, what would be your recommendations?  What products to use etc.  When should I start using it?
Thanks
Re: New paint protection
« Reply #1 on: December 28, 2008 - 04:48:46 PM »
Is this car being stored indoors, or outside?
I have heard to wait 6 weeks or more before applying wax to a new paint job...
If this car is indoors, then no problem with a cover. If this car is outside, then keep in mind high winds could move the car cover around some, thus the possibility of putting minor scratches in the overcoat. I think that is where the concern lies..
Offline elitecustombody
  • Supra collector
« Reply #2 on: December 28, 2008 - 06:19:56 PM »
How old is the paint job? I s it base/clear or single stage?
Stefan B
Offline peterro
    • The Pistonhead
« Reply #3 on: December 28, 2008 - 06:37:17 PM »
The paint is about 8 weeks old and it is a base/clear. It will also be stored inside. I just checked the car cover warning again and it simply said to contact the painter for when and how to use the cover.  Not much to go on.
Thanks.
  • Supra collector
« Reply #4 on: December 28, 2008 - 07:46:39 PM »
where are you located? I'd wait another month or two and then put the cover on, some paint depending on application will stay soft for a while and the cover may leave print from fabric if it's tight, especially on the corners and sharp bodylines,it's safe to wax it now if you wish to do so
Stefan B
Offline peterro
    • The Pistonhead
« Reply #5 on: December 28, 2008 - 07:57:26 PM »
Thanks, I'm near Portland, OR.  Any recommendation on wax products?
Offline vinb
« Reply #6 on: December 28, 2008 - 08:14:36 PM »
I use Mother's Carnauba with no cleaners in it, works great for me...
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #7 on: December 28, 2008 - 08:17:51 PM »
I had my car painted about a year ago and had the PPG Concept 200 clear coat applied. At the time I was told it was the best stuff on the market. My painter told me to absolutely NOT apply any wax for at least 3 months after the paint job. All I can go on is what he said as I know NOTHING on paints, coatings, cure times or any other product data, but I am sure if you looked up the product on the web (like PPG products) you could find out a good bit of info!! I would wait at least another few weeks before waxing. :2thumbs:
                                                               Matt B.
Matt
  • Supra collector
« Reply #8 on: December 28, 2008 - 08:39:55 PM »
It's safe to wax it, I've owned paint shop for nearly 20 years and never had any problems using wax even on 1 day old paint,
Meguiars Tech Wax is very user friendly and gives great results,
Has the paint been colorsanded and polished?
Stefan B
Offline peterro
    • The Pistonhead
« Reply #9 on: December 28, 2008 - 08:52:15 PM »
Excellent. It has been sanded/polished.
  • Supra collector
« Reply #10 on: December 28, 2008 - 09:13:50 PM »
do you know what system or products the paint shop used to polish the paint? I'd use cleaner wax to remove any sealants that interfere with wax bonding before applying wax,
Stefan B
Offline peterro
    • The Pistonhead
« Reply #11 on: December 28, 2008 - 10:10:53 PM »
I don't know what they used but I could find out.  I think if I just start with the right products, I should be in good shape for the long term.
So since you recommended the Tech Wax, would you then recommend the deep crystal cleaner and polish to prepare for the wax?
  • Supra collector
« Reply #12 on: December 28, 2008 - 10:36:56 PM »
yes, you will have to use cleaner wax before application of sealer wax if you want the best results, if you have plenty of time ,go to http://www.autopia.org/forum/, you'll find out more than you want to know about detailing and preserving paint & interior and everything else
Stefan B
