Author Topic: 400 questions  (Read 1684 times)
Offline sparkybr74mr
400 questions
« on: December 28, 2008 - 04:31:17 PM »
I recently found a 73 newport in an old garage, The car is equiped with a 400 engine, I was planning a conversion of my challenger from a 318 to a 440 at some point in time. I do have a 440 rb that was pulled out of a motor home for the swap. Both engines I'm sure will need rebuilt. My question is, which way is the best way to go? I can get the newport for little to no money I'm sure. I don't see many car's with the 400 so I don't know if it is a good motor to invest in. Any input will be apreciated. Steve
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: 400 questions
« Reply #1 on: December 28, 2008 - 04:36:44 PM »
From what I know, the 400 is mostly used to make a stroker.  As far as I can tell, if you are not going to stroke it, then you should probably go with the 440 you have.
  I say, pick up the newport and drive it as original.
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: 400 questions
« Reply #2 on: December 28, 2008 - 04:44:33 PM »
Get the 400 and sell it and stick with a 440 block.  The 400 is usually used to make high CID strokers due to the thick casting of the block, if that is your application then go for it if you just making a crusier steet/strip go with the hot 440.  If it were me I would stick with the 440 and sell the 400 for a profit.   :2cents:
Don
Member Since January 14, 2002
Re: 400 questions
« Reply #3 on: December 28, 2008 - 04:54:23 PM »
Let me throw this back at you...
 How do you plan to use the car? Just a Sunday cruiser, or maybe something more serious?
nivvy
Re: 400 questions
« Reply #4 on: December 28, 2008 - 05:09:12 PM »
put the 440 in it and put 318 stickers on the hood..... sell the 400 ...
Re: 400 questions
« Reply #5 on: December 28, 2008 - 05:30:12 PM »
You ever drive a good high compression, good headed 400?  They will hold there own.   You said you have to build it. Either one needs pistons
Offline Oldschool
  • Member Since 9-05-06
Re: 400 questions
« Reply #6 on: December 28, 2008 - 05:41:01 PM »
And if you are gonna build it, you might as well stroke it.  400s lend themselves very well to a stroker setup...    :2thumbs:
Ken  --  In Georgia
Re: 400 questions
« Reply #7 on: December 28, 2008 - 05:42:45 PM »
And I want that 360 you were talking about OS, but waitng to hear on that 400 stroker stuff that is close by :banghead:
Re: 400 questions
« Reply #8 on: December 28, 2008 - 06:08:54 PM »
If you do decide to go with the 400 then read this:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4862818&Main=3506113
Quote:
The "Real" {4/4/71 to 10/10/71} thick web 230 blocks Do have a following and are Desirable, If not to use it but even, Just to own one!
Offline Supercuda
Re: 400 questions
« Reply #9 on: December 28, 2008 - 06:14:36 PM »
Why 400s are used for stroker builds: 1) They have the biggest bore of any MOPAR bigblock; 2) in relation to their crankshaft bearing bores, they have thicker main webs than 440s; 3) when you are finished, they still look like a stock low-deck bigblock, and will fool a lot of people that are looking for the ID pad to tell them  you have serious inches; and 4) they are dirt cheap to buy; even cheaper than most 440s will be. I like the idea of building smaller engines myself, but the stroker won't go away any time soon. The old axiom, "there's no replacement for displacement;" always holds true. Build either engine into a stroker, as the money to build a stock stroke engine is not much less than a well-thought-out stroker. Cylinder heads now exist to feed monster cubic inches, and it is easy to get 1-1.5 hp per cubic inch without stressing the engine. I would keep the 400 and stroke it, and sell the 440 to somebody that wants a heavier engine when they are done building their stroker.
Offline moper
Re: 400 questions
« Reply #10 on: December 28, 2008 - 07:01:22 PM »
I think I would also consider the 400 car as a total parts donator... everything from the pulleys and brackets to kickdown and driveshaft... So if this is a cruiser car, I'd consider a simple swap of everything. All depends on what you want to do, and what you have to spend.
To add to the 400 "plusses" the B wedge fits better in an A body in terms of clearance for headers... I also agree with not going past a 3.915 stroke (470ish cubes) in them.
Re: 400 questions
« Reply #11 on: December 28, 2008 - 07:25:02 PM »
the 400 with 440 crank & rods will eat a 440 with similar combo, it will come up to 451 CI but will also reduce the rotating mass by 7 lbs allowing it to rev easier & with the same parts will be faster , however doing the same thing to the 440 & taking it up to 512 CI works just as well
Offline 71chally416
    • The Streetwalker
Re: 400 questions
« Reply #12 on: December 28, 2008 - 08:19:57 PM »
 :iagree:  I got well into the 7's using a 400 block with B-1 heads in a Road Runner body with stock dimensions. Not exactly the most aerodynamic car.
Offline vinb
Re: 400 questions
« Reply #13 on: December 28, 2008 - 08:53:34 PM »
Stroke it to 451, sounds good to me...should make good power...and a little lighter too....
Offline moparmaniac59
  • Drive it like ya stole it!
Re: 400 questions
« Reply #14 on: December 29, 2008 - 11:58:18 AM »
I just wanted to jump in on this rather than starting a new thread as it applies here to this one. Interesting info. I have a 400 on an engine stand in my garage and also a 440. I was planning on stroking the 400. My question is: Are all the external engine parts such as brackets, pulley hubs, water pump, power steering ect interchangeable between the two engines?? :clueless: Thanks guys!
                                                            Matt B.
Matt
