Author Topic: Rallye Dash Install?  (Read 1090 times)
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« on: December 28, 2008 - 04:59:17 PM »
Does anyone have a step by step with pictures of a standard dash to Rallye Dash install?  I have had some nice weather and I want to take full advantage of it.  Any help with this would be a HUGE help!
Don
Member Since January 14, 2002
Re: Rallye Dash Install?
« Reply #1 on: December 28, 2008 - 05:09:32 PM »
Don.
  What do you have??   :dunno:
Gauges, switch panel? You need the heater panel too, depending if you have AC or not. Rally gauge wiring harness? You'll need a new oil pressure sending unit.
« Reply #2 on: December 28, 2008 - 05:24:06 PM »
That's the dash my friend Mark sent to you?   Come on over, im home
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #3 on: December 28, 2008 - 05:33:48 PM »
You don't need a rallye dash wiring harness. You can modify the the stock harness. You will need to take the oil pressure idiot light and cut it off. You will use the grey wire from the idiot light to connect to the oil pressure gauge and I believe the other wire is used as power for the clock. Then you need to run new wires for the tach. Everything else should be fine as far as wiring goes, all of the wires go in the same spots on both standard and rallye gauges. It would be better to install the rallye gauge light panel with the four lights instead of three, but not necessary if you don't have it. As stated you will need to change the oil pressure sender in the block, most auto parts stores have them in stock and they cost about $25 I think. If you have removed e-body instruments before, it's the same thing just with installing different gauges but they go in just the same. Sorry I don't have any pics, hope this helps and if you need any more details just let us know.
1996 Dodge Viper GTS Coupe
Offline VTMopar
« Reply #4 on: January 02, 2009 - 08:14:50 PM »
CudaGuy -
Please take good notes - I'm going to tackle the same project in early April, so would appreciate any additional tips .....   :wave:
VT Mopar
VT MOPAR
