Author Topic: 4 pin pictures  (Read 2190 times)
sleepychallenger
4 pin pictures
« on: December 28, 2008 - 07:52:56 PM »
does anyone have any pictures of challengers with 4 pin lift off hoods and how the rear pins were mounted? please post up.
Drew
Re: 4 pin pictures
« Reply #1 on: December 28, 2008 - 08:03:41 PM »
Most people use the a12 6pk hook kits. But you also need to consider a center front pin if going fast and air inducted on a thin pin on hood
sleepychallenger
Re: 4 pin pictures
« Reply #2 on: December 28, 2008 - 08:20:43 PM »
what do the a12 hook kits look like?
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: 4 pin pictures
« Reply #3 on: December 29, 2008 - 07:29:00 AM »
Here are 2 pics. I can get better ones if needed. Restoring an A12 Bee right now.
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
sleepychallenger
Re: 4 pin pictures
« Reply #4 on: December 29, 2008 - 08:57:27 AM »
would you reccomend installing those brackets and filling the rear holes that are already in the hood, and how would i install those brackets?
« Last Edit: December 29, 2008 - 09:02:17 AM by sleepychallenger »
Re: 4 pin pictures
« Reply #5 on: December 29, 2008 - 09:00:48 AM »
It's a cleaner look. I think the back brackets bolts to around where the hinge would be, and the front factory hood pin holes on your car. You won't have to drill any holes anywhere to make any other damage to your car in the cowel.
Got a picture of your new hood Drew?
sleepychallenger
Re: 4 pin pictures
« Reply #6 on: December 29, 2008 - 09:03:13 AM »
if i can get my wife to email me the pictures i will have some to post soon. I am picking it up from a member here on the board this weekend  :bigsmile:
sleepychallenger
Re: 4 pin pictures
« Reply #7 on: December 29, 2008 - 09:06:23 AM »
i guess that means that i am going to be posting something in the parts wanted section.  :bigsmile:
sleepychallenger
Re: 4 pin pictures
« Reply #8 on: December 29, 2008 - 01:22:21 PM »
pic
sleepychallenger
Re: 4 pin pictures
« Reply #9 on: December 29, 2008 - 07:33:37 PM »
do you think they will mount where my hood hinges are or should i try to fab up my own?
sleepychallenger
Re: 4 pin pictures
« Reply #10 on: December 29, 2008 - 11:03:20 PM »
more pics
« Last Edit: December 29, 2008 - 11:06:16 PM by sleepychallenger »
sleepychallenger
Re: 4 pin pictures
« Reply #11 on: January 15, 2009 - 11:14:21 PM »
anyone need a set of A12 brakets? $25. I go them, mounted them, and found out my hood pin needs to be 3 inches longer to use them on the challenger. they mount way to low to use on a chally.
Re: 4 pin pictures
« Reply #12 on: January 16, 2009 - 06:52:32 AM »
Drew, couldnt you use all thread to adjust the lenght?  I have seen it done before that way
sleepychallenger
Re: 4 pin pictures
« Reply #13 on: January 16, 2009 - 06:42:26 PM »
all thead? dont know what that is. i already drilled the holes, i got really pi$$ed off and decided to just drill
sleepychallenger
Re: 4 pin pictures
« Reply #14 on: March 14, 2009 - 08:13:58 AM »
ok, anyone know how the rods are made to lift the hood up off the car for display?
