Aeromotive ss fuel pump
Author Topic: Aeromotive ss fuel pump  (Read 2548 times)
nivvy
Re: Aeromotive ss fuel pump
« Reply #15 on: December 29, 2008 - 08:02:51 PM »
How are you guys running a return line into the tank? Whille i was changing my passenger side spring hanger i did notice that there were like 4 or 5 tubes ging into the top of the tank. What are those tubes used for?
the problems with 1972 is the year change of the gas tank... im thinking yours is like mine. let me find a pic.....  :working:
nivvy
« Reply #16 on: December 29, 2008 - 08:04:24 PM »
see my one pic above........  :working:
nivvy
« Reply #17 on: December 29, 2008 - 08:05:24 PM »
 :swaying:
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #18 on: December 29, 2008 - 08:08:01 PM »
a tell tale sign of a return needed is if you fuel regulator guage needle bounces erractically... my buddies triple nickle nova that ran high 8's started doing that at the regulator and he ran a return hose back to the tank and it went away...... my other buddies 8 second mopar didnt do it at all  :dunno: he had a high dollar magna fuel system though  :working:
If its 1320 feet at a time with a carburetor on the motor its probably no big deal. on the street it could go eather way if it works why mess with it.  :working:
(It will help cool the pump)  :icon16:
Its a must with EFI if that matters I know you are not running efi  :rofl:
« Last Edit: December 29, 2008 - 08:10:12 PM by thedodgeboys »
Go Fast & Have Fun...
nivvy
« Reply #19 on: December 29, 2008 - 08:09:34 PM »
they were both track cars only.... kinda weird if ya ask me......  :dunno:
Offline Justins72
« Reply #20 on: December 29, 2008 - 09:16:34 PM »
Funny how i was just under the car about an hour ago looking at it and i cant remember what if it looked like yours stroker. I will take picures and post them up of the tank tomorrow morning. So for the pump i should be fine mounting it to the frame rail even though its about at the top of the tank? It will be level with the fittins to the sending unit.
Offline go-fish
« Reply #21 on: December 29, 2008 - 09:31:46 PM »
I had a new tank and I welded a fitting on the tank for the return. Use a 1/2 p/u tube too. You don't want drink a keg with a straw. 1/2" p/u's werent stock I believe but you can get one from Mancini's or the like.
Before you install the new 1/2" pickup, snip off the vent tube and drill a hole, get a threaded nipple fitting and a nut, whalla! Or weld it on there. Easy day!
Offline go-fish
« Reply #22 on: December 29, 2008 - 09:33:29 PM »
Right here!
Offline go-fish
« Reply #24 on: December 29, 2008 - 09:55:21 PM »
I should have done that Stoker. Excellent tip.
nivvy
« Reply #25 on: December 29, 2008 - 09:57:28 PM »
thx go fish..... im probably gonna sell the sending unit / filter / pump to the aeroquip regulator real soon.....  :working:
It will be a nice bolt on setup for someone...........  :working:
Offline Justins72
« Reply #26 on: December 31, 2008 - 03:23:16 PM »
was looking through mancini and found a 1/2 fuel pick up with a 1/4 return. Would 1/4 be okay to use or would i need something bigger? Also when looking at my gas tank and where the tube is all thats there is the line and the electrical conector so there is no vent tube on it.
Offline 73EStroker
« Reply #27 on: January 02, 2009 - 01:44:12 PM »
Stroker has what I have - that is a return line back to the fitting on the sender. I have a 3/8" line to the pump (not sure of Stroker's -1/2"??) and the return is the 73 style 1/4" vapor line made into a positive/continuous return back to the tank with a small restrictor near the carb fuel rail. Keeps cool fuel near the float bowls all the time. I have too much rubber line on mine for drag racing but will change it out to braided eventually.
The flashlight on the right hand side of the carb fuel rail is sitting on the fitting that has the 8-32 restrictor nut sitting in it. Fuel pressure stays at 5 PSI even while getting the engine up to a steady 3000RPM. I will be protecting the rubber at the tank from the exhaust heat.
Barry (Salmon Arm)
    • THE DODGE BOYS
« Reply #28 on: January 02, 2009 - 02:21:11 PM »
was looking through mancini and found a 1/2 fuel pick up with a 1/4 return. Would 1/4 be okay to use?
Yes it should be ok for a carb type return.  :grinyes:
