Author Topic: Rallye Hood fit???  (Read 3884 times)
Offline 426HEMI
Re: Rallye Hood fit???
« Reply #15 on: January 01, 2009 - 08:57:03 AM »
I had one that fit that way and it was a combination of the molding on the fenders and the hood actually being bowed making it shorter.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline jmartin99
« Reply #16 on: January 01, 2009 - 12:05:32 PM »
Thanks for the help guys.  I looked at the fender trim last night and it does not look like I can close up the gap much by loosening it and trying to move it.  It almost looks like the flange that the fender trim goes against is bent out a little.
The hood does not appear to be warped or bent but that could be the issue too.  The owner talked about trying to find another reasonably priced hood and getting it painted an put it on to see.  This car had hail damage after it was painted and they fixed it but did not do a very good job.  There is a spot on the edge of the hood that looks really bad in the sunlight.
Jeff
Offline sprecks
« Reply #17 on: January 01, 2009 - 09:16:25 PM »
You said you don't know if they are original or aftermarket fenders. I had this problem when I put aftermarket fenders (Goodmark) on my car. Luckily it was before I painted the car so I could fix it. The passenger fender was 3/8 inch too long.
you can call me Jay
I've seen sicker dogs get well.
1971 Challenger Vert - 472 Hemi EFI
1969 Road Runner 440/Auto
2017 Ram Laramie 1500 - Hemi
Offline jmartin99
« Reply #18 on: January 02, 2009 - 12:24:28 AM »
Well, after looking at the hood again today, I do think it looks like it is warped or bent.  I closed the hood and the hood is about a 1/4 inch or more higher in the center of the hood than the fender.  Both ends of the hood are even with the fender.
How did you fix the fender that was 3/8 too long?
Jeff
Offline sprecks
« Reply #19 on: January 02, 2009 - 07:42:15 AM »
I determined that the end that was too long was up towards the windshield. With a die grinder, I cut a very thin (3/8" x ~7") pie shaped slice out of the fender about a 1/2" forward from the back edge. I then hammered the gap closed, welded the seam and ground the weld smooth.
you can call me Jay
