Author Topic: Fuel Inlet Hitting The Back Of My A/C Unit  (Read 613 times)
Offline daveh
« on: December 31, 2008 - 09:24:54 AM »
Hey guys I am installing a new Demon carb and the duel inlet gas line is hitting the back of my A/C unit.  Does anyone make an inlet that enters from the side?  I can't be the first one that has encountered this.  It's on my 71 Challenger 340.  Thanks for your help
Offline 422STROKER
  • Member Since 6/3/06
Re: Fuel Inlet Hitting The Back Of My A/C Unit
« Reply #1 on: December 31, 2008 - 10:30:13 AM »
What kind of inlet do you have now?  A pic would help.
Tom
This looks like it would be pretty even with the end of the carb.
Tom
Offline daveh
« Reply #2 on: December 31, 2008 - 10:40:51 AM »
Just the typical duel chrome inlet
Offline 422STROKER
« Reply #3 on: December 31, 2008 - 11:03:15 AM »
That one looks quite a bit longer to me.  You could make one from a "T" and some fittings/pipe if you wanted.
Tom
Tom
« Reply #4 on: December 31, 2008 - 11:15:14 AM »
you may have to buld one using a T in between the 2 bowls
« Reply #5 on: December 31, 2008 - 03:09:31 PM »
Turn it around backwards  or like chryco says.   You have MANY options
