Author Topic: DO YOU HAVE TO REMOVE THE GAS TANK ?  (Read 1980 times)
Offline cudaneil
  • Mopar or Nocar ?
« on: December 31, 2008 - 10:06:51 AM »
              Hi,   I have a nos sending unit to replace my "work when it feels like it"  crappy aftermarket sending unit.
                   Do i have to remove the tank or is there an easier way  ?        :clueless:
just one more job to do..................  (O----{|||}----O)
Offline 422STROKER
  • Member Since 6/3/06
Re: DO YOU HAVE TO REMOVE THE GAS TANK ?
« Reply #1 on: December 31, 2008 - 10:19:00 AM »
Run the tank down to <1/2 way and jack the car up on the drivers side.  Should be good to go.
Tom
Tom
Offline cudaneil
  • Mopar or Nocar ?
« Reply #2 on: December 31, 2008 - 10:30:21 AM »
Tom
  Slight problem with that Tom............my cuda has an exhaust silencer box each side of the gas tank.   :faint:
Offline 422STROKER
« Reply #3 on: December 31, 2008 - 10:34:49 AM »
 :woo:  You may need to drop the tank.lol.
I had just pipes in my way and it went easy.
Tom :eek4:
Tom
« Reply #4 on: December 31, 2008 - 10:37:34 AM »
I have always been able to get the sending unit out without dropping the tank , you may have to pull the heat sheild out to get to it
Offline cudaneil
  • Mopar or Nocar ?
« Reply #5 on: December 31, 2008 - 10:57:07 AM »
       Looks like my car has a non standard exhaust, it has straight through pipes with a box at the end and the tips welded to each box !
          thats why there is no room alongside the tank.
           Will have to drop the exhaust on the drivers side to get the sending unit out in that case.  Easier than dropping the tank though !!!
            Thanks for letting me know that the sending unit will come out anyway.               Neil.   :thumbsup:
Offline 72bluNblu
« Reply #6 on: December 31, 2008 - 03:26:19 PM »
I had the stock silencers back near mine and was able to get it out, I just jacked the car up on that side and fiddled with it for a bit. Took a few tries to figure out how to maneuver it, but it wasn't that bad. I didn't drop the tank or the exhaust.
Offline cudaneil
  • Mopar or Nocar ?
« Reply #7 on: January 01, 2009 - 03:06:04 PM »
       Ok,  Thanks for that.  im going to have a go at it and see what happens.    There is only a 1" gap alongside the silencer where you can see the sending unit,so i
                 think the exhaust will have to be removed to actually get the sending unit out.    :banghead:
        :cheers: Neil.
« Last Edit: January 01, 2009 - 03:08:16 PM by cudaneil »
« Reply #8 on: January 01, 2009 - 03:22:22 PM »
Looks like mine would to with heat shield and muffler right there. But try undoing the tip bracket hanger, resonator bracket and just unscrew the muffler shield and it may come out. also let the springs n tires hang a bit for more room. The tip bracket has to be undone to take the muffler shield off all the way
nivvy
« Reply #9 on: January 01, 2009 - 03:48:45 PM »
I did mine without removing the tank..... put the  car on jack stands in the rear and pulled the wheel off and the suspension dropped down.....  :working:
Offline cudaneil
  • Mopar or Nocar ?
« Reply #10 on: January 04, 2009 - 03:33:53 PM »
   Ok,  Thanks guys..................decided not to tackle the job yet, as its turned very cold here at the moment in the uk  ( -6 degrees with a freezing wind)
                                                         Your help is much appreciated!       :cheers:    Neil.
