As it is in every case, the cam depends on your compression, the pistons you use and the notches they have and what's done to your heads. Stock heads break over (stop gaining flow) at around .500" lift, so any more than that is kind of a waste. You have to consider the valve spring installed height too and what cam lift it can accomodate.
