Author Topic: Frame Connectors PICS  (Read 3415 times)
Offline go-fish
Re: Frame Connectors PICS
« Reply #15 on: January 02, 2009 - 08:27:25 AM »
Yeah yeah yeah. pics!
Offline ShelbyDogg
« Reply #16 on: January 02, 2009 - 09:29:56 AM »
Stroker,  Who put you rear floor pans in?  They didn't push the pans all the way back to the rear frame rails before welding them in. The floor is a big part in a unit-body.
nivvy
« Reply #17 on: January 02, 2009 - 10:12:17 AM »
well i think its a goodmark panel not sure of the quality fit....I have always wondered that myself......both side are like that equally... also where things are now my seatbelts are in the right locations  :dunno:
« Last Edit: January 02, 2009 - 10:35:23 AM by StRoKer »
Offline ShelbyDogg
« Reply #18 on: January 02, 2009 - 11:31:51 AM »
I put a set of AMD floors in my Vert and had to do some hammering to close up that gap. My gap was nowhere as big as yours. If you look at the rear section, this floor section makes up 3/4s of the side to side crossmember, that ties your two rockers and rear framerails together.   That should be closed up or water will go right into your frame rail and start rusting the side that holds your front leafspring bracket.
nivvy
« Reply #19 on: January 02, 2009 - 11:48:08 AM »
thx for the pic... ill get that fixed... there is metal shop 2 blocks from me  :2thumbs:
« Last Edit: January 02, 2009 - 11:52:26 AM by StRoKer »
Offline Chlngrcrzy
« Reply #20 on: January 03, 2009 - 11:52:12 AM »
I have installed probably 15+ sets using 1x2 tube
yeah I make my own & weld them in
Sweet. With all the welding and fabrication that i have done, i should be able to tackle building a set of frame connectors. :2thumbs:
Offline Katfish
  • 70 Challenger
« Reply #21 on: January 03, 2009 - 09:07:33 PM »
Make sure you take pics so I can copy what you come up with.   :bigsmile:
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #22 on: January 04, 2009 - 01:10:07 PM »
I like using 2x3 tube on edge, I slit the floor and rear frame at the end, slide it into the frame about 3 or 4 inches and then up into the floor weld the floor to the sides of the tube and to the frame ends.
It raises the carpet a bit inside but no one will notice.
It gives the car a much better all around connection that way.
Jackson from Toronto.
Offline go-fish
« Reply #23 on: January 04, 2009 - 02:03:57 PM »
Do you have any pics?
Offline IMNCARN82
  • LeDZeP
« Reply #24 on: January 04, 2009 - 02:58:02 PM »
 :popcorn:   Yeah pics would be cool.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline boydsdodge
    • Boydsdodge
« Reply #25 on: January 04, 2009 - 04:03:36 PM »
Sorry I don't. I am pretty modest about my body.
Offline ShelbyDogg
« Reply #26 on: January 04, 2009 - 04:40:22 PM »
I planned on the 2x3 boxed also, then bought the XV connectors. I didn't put anything in yet but after seeing the work involved putting those in, I might still go with the 2x3s.  I usually don't have anyone in my back seat and the Vert really requires the strength of the full add-in.
Offline boydsdodge
    • Boydsdodge
« Reply #27 on: January 04, 2009 - 05:21:22 PM »
I bought a set of US car tool sub frame connector same as XV, and I decided against using them and going with my 2x3 tube cut floor style.
The XV and US car tool frame connectors are a bit big and a lot of work to install.
Plus if I want to ad a roll bar in the future the 2x3 connectors will be an excellent mounting point for the bar.
« Reply #28 on: January 07, 2009 - 11:46:01 AM »
BoydsDodge,
Do you want to sell them if your not using them? If so how much?
Offline ShelbyDogg
