Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Chrome Box 4 pin ballast question
« previous
next »
Print
Pages:
1
2
Author
Topic: Chrome Box 4 pin ballast question (Read 3470 times)
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: Chrome Box 4 pin ballast question
Reply #15 on:
January 02, 2009 - 05:50:55 PM »
From experience, if you can fire up a car when it's below freezing, you HAVE spark.
If you have a weak spark, it is REAL easy to flood the engine in extreme cold weather.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
matt63
Sr. Member
Reply #16 on:
January 02, 2009 - 08:24:57 PM »
Changed to the 2 pin ballast and I now have almost double the voltage at the coil (approx. 6 volts). Perhaps it will be higher with the engine running.
Logged
Matt in Edmonton
'68 Valiant
Chryco Psycho
Administrator
C-C.com Guru
Reply #17 on:
January 02, 2009 - 08:55:14 PM »
should be higher yet , battery should be 13.2 v so you are starting off low & it should be very close to the same voltage at th eballast so check bulkhead connections for resistance as well as you are losing some between the battery & ballast
Logged
matt63
Sr. Member
Reply #18 on:
January 02, 2009 - 09:20:36 PM »
Yes, will do tomorrow. Thanks CP.
Logged
Matt in Edmonton
'68 Valiant
matt63
Sr. Member
Reply #19 on:
January 03, 2009 - 08:34:39 PM »
Looks like I am losing 0.9 volts between the starter relay and the engine side of the bulkhead connector which means I am losing it in the wire/fusible link?
Have you seen this before? I only lose 0.4 volts between power in/out of the bulkhead. My electrical know how on this car is a little rusty and I'm tired as I spent all day fixing frozen water lines at my neighbours house. He went away for 2 weeks and nobody was checking his house. The furnace went out days ago
Logged
Matt in Edmonton
'68 Valiant
71chally416
Resident
Reply #20 on:
January 03, 2009 - 08:44:50 PM »
That's why I don't use the old Chrysler system. My digital-6 hooks directly to the battery.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #21 on:
January 03, 2009 - 09:52:32 PM »
Funn
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
