Forgot to mention, I run Drag radials on my Mach 1, they are really good, pump the pressure up to 30 psi on the street and they corner better than regular street tires, however, there always a negative. When it rains, and not very much rain either, the drag radials are very slippery, the tread depth is so small that is really does does nothing to push the water away. So, running on the front would be super scary given that I run the street Nt555 on the front and the NT555drs on the back, the street tires atleast help push some water away before my rears get to them, running the race tread, even the road course racing design on the front will not help the rear much; = wrecked car.
Then again, you may never drive in the rain.
Oh, and I only get 8k miles out of the Drag radials, that is the best I have done and they were bald. Could be alot of
Earlier, someone mentioned not to do a big burnout, when I go to the strip, I usually do a decent burnout for the first trip down the strip, then after that I only spin them to clean them off. They stick really well but are hell on parts, rear ends, drive shafts, trannys, etc. I run 12 psi at that drags.
The cuda will have Drag Radials on the back when it is done, really a must have if you plan on 600+ TQ.
