Author Topic: Coil Question  (Read 1498 times)
Offline TRIPLE-GREEN
    • Coupe Custom Accessories
Coil Question
« on: January 02, 2009 - 06:41:33 PM »
Hello,
   Got my new intake (4brl) in my 318. Runs great. But I wanted to replace the coil. I have a pretty much stock motor. Other then the new edelbrock carb and stock cast iron 360 intake.
   Be nice it was a freebie and seems to work great.
   I wanted to know, keeping in mind I have stock electronic ign. Can I just put on a performance coil. Or will that be to much for the old system? Will I see any differance over the old stock coil?
   I went a little big on the carb and it is running rich. I was going to jet it down, but I was told it will be good once I get on the duel exhaust. I am running a 600 cfm. Runs amazing but rich.
Re: Coil Question
« Reply #1 on: January 02, 2009 - 07:05:14 PM »
The High output coil will work & help with your ign as is
where does it run rich , idle or cruising , jetting only affects cruise & full throttle idle could be float level too high or mixture screw not adjusted correctly
Re: Coil Question
« Reply #2 on: January 02, 2009 - 07:12:56 PM »
I was told he put the idel mixture screws all the in and the car continued to run at idle. it also smells rich while driving.
Re: Coil Question
« Reply #3 on: January 02, 2009 - 07:27:02 PM »
Air vacuum leak somewhere. It is getting air in another location
Re: Coil Question
« Reply #4 on: January 02, 2009 - 08:04:22 PM »
you may have an internal fuel leak through the power valve or the gasket between the body & metering block
the mixture screws on most turn in to lean the mix & it should stall if they are all the way in typically they should be 1-1.5 turns out , ifi you had an air leak you would  be lean you have to have an internal fuel leak , I assume the carb is not new
Offline Aussie Challenger
Re: Coil Question
« Reply #5 on: January 03, 2009 - 04:31:12 AM »
  Definetly in the carb, check needle and seat not sealing or float level too high. You said it was a 2nd hand carby maybe somebody played around before with it or even the floats are sinking soaking up fuel,   :2cents:
Re: Coil Question
« Reply #6 on: January 03, 2009 - 11:19:48 AM »
No it is a brand new edelbrock out of the box. From my shop. I will check with him again to make sure that was a correct statement. I just got it back yesterday and have not had any time to play with it. (Due to work)
But if that coil will help and not hurt the system then I will get one. THANKS!!
Any additional comments welcome :popcorn:
« Last Edit: January 03, 2009 - 01:10:00 PM by TRIPPLE-GREEN »
Offline moper
Re: Coil Question
« Reply #7 on: January 04, 2009 - 12:15:11 PM »
If it smells rich all the time, it could be rich. What do the plugs look like? As for a coil, i stay far away from Accel, I do use a lot of MSD Blasters with good results. In most cases, Edelbrocks come lean. But with a stock 318, it can run rich. You need the strip kit for it and a vacuum gage to properly tune the carb. I'd bet it needs a different set of step up springs and probably a smaller jet and rod combination to be perfect.
Re: Coil Question
« Reply #8 on: January 04, 2009 - 12:36:04 PM »
 nothing I said makes sense if you do not have a Holley style carb
Offline bordin34
Re: Coil Question
« Reply #9 on: January 04, 2009 - 02:59:44 PM »
Maybe you aren't running on the idle circuit and are a little bit into the primaries.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
