Author Topic: Leaf Springs for AAR Cuda  (Read 5453 times)
Offline cwestra
Re: Leaf Springs for AAR Cuda
« Reply #15 on: January 11, 2009 - 08:51:59 PM »
Thanks, I'll check them out tomorrow.  I believe T/A and AAR use the same spring, correct?
I had a guy quote me locally to replace just the top leaf.  He would have it made and shipped and would run me $174 per side plus shipping (approx. $12) and reassembly (approx. $35), per side.  Total would be approx. $430 which is about what it sounds like I could get a new set for.  Do you know if Eaton supplies to Year One?  I can get them through them but they are a big more.
I wonder if Eaton would consider using my lower half leaf which has the part number stamped on it.
« Last Edit: January 11, 2009 - 08:59:33 PM by cwestra »
Corey - in Northern Indiana
Alaskan_TA
« Reply #16 on: January 11, 2009 - 09:10:38 PM »
Correct.
Offline ShelbyDogg
« Reply #17 on: January 12, 2009 - 09:06:29 AM »
Yours look really rusty.  I changed my mind; maybe you better get a NEW set. Rusting and sandblasting thins out the springs a little.
Offline cwestra
« Reply #18 on: January 12, 2009 - 11:48:15 AM »
Checked with Springs-'N-Things today.  They quoted only $240 for a set of AAR springs.  Seems like a great deal.
Offline ShelbyDogg
« Reply #19 on: January 12, 2009 - 02:13:24 PM »
I guess that doesn't sound too low since the Mopar XHD springs are $95 a piece. Save your bottom spring and blast it to see if looks good enough to install on the new set.
Offline cwestra
« Reply #20 on: January 12, 2009 - 02:56:58 PM »
That's a good idea.  I will.  Thanks.
« Reply #21 on: January 12, 2009 - 05:03:20 PM »
Just a thought...
Springs-N-things(Espo) also sells the rear shackles and the big bolt for the front of the leaf spring if your's are too rusted to save. I totally boogered up my shackles trying to get them apart.   :pullinghair:
Offline cwestra
« Reply #22 on: January 12, 2009 - 05:06:09 PM »
Actually, I did end up getting those and a set of U-bolts.  The price was right and I certainly did need them.  Now I just need to get the old eye bolts off the mounting bracket.  They're fused pretty solid.  Thanks for the tip, though.
Offline ShelbyDogg
« Reply #23 on: January 12, 2009 - 07:49:01 PM »
That front bolt is tight.I cut the nut off with a cutoff wheel and was able to get a nut from my harware store to replace it.
Offline cwestra
« Reply #24 on: January 12, 2009 - 09:01:17 PM »
Yea.  I'll probably do the same.
