Author Topic: Belgium Cuda  (Read 489 times)
Belgium Cuda
« on: January 06, 2009 - 05:30:32 PM »
 Your inbox is full
open it up, sorry about the bad news But ....
 the bolt is designed to have a certain amout of stetch or spring load to keep it tight , being under torqued it will have no stretch , I have also used a drop of locktite in the past on the bolts to be sure they do not loosen
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: Belgium Cuda
« Reply #1 on: January 07, 2009 - 01:06:08 AM »
Your inbox is full
Thanks for the bad news :'( Is it something that would happen right away or with moore mileage? I think what I mean is, do it right now or it could be to late.
Is it possible to reach with a torquewrench if the engine is in the car?
« Last Edit: January 07, 2009 - 04:27:07 AM by Belgium Cuda »
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Belgium Cuda
« Reply #2 on: January 07, 2009 - 10:58:00 AM »
it will be ok , just go in & torque them unless on eof the bolts is already loose then check the brg for damage
