Author Topic: stealth heads on 383  (Read 646 times)
Offline MLcuda
« on: January 06, 2009 - 07:34:02 PM »
Why cant i bolt a pair of stealth heads on a orginal bore 383 ???
They said  at 440source, minimum 0,030" over
Will edelbrock prf.rpms works without boring
My engine is like new in the sylinderwalls.still see crosspattern from honeing
1971 Barracuda Gran coupe
Re: stealth heads on 383
« Reply #1 on: January 06, 2009 - 07:40:33 PM »
Maybe because of 214/181 valves. You'd need to knotch the block I would assume like the ole max wedges had
« Reply #2 on: January 06, 2009 - 08:45:14 PM »
 :iagree: That would be my guess the edge of the valve will not clear the bore
Offline MLcuda
« Reply #3 on: January 07, 2009 - 02:30:59 AM »
Thanks!!
Offline moper
« Reply #4 on: January 07, 2009 - 12:16:33 PM »
You will need to relieve the bores for the intake valve. On a 4.25" or 383 based hi performance build, that should be done anyway.
