Mine doesn't actually hit anywhere. When I run my hand over the wheel well trim piece, my fingers will touch the tire at the top of the arch so this means that maybe I have a 1/2 inch gap between the two. To me this says when I am driving and hit a bump, I may put the fender well trim piece into the tire. Not something I am looking forward to. I did order the wheels with the 4.5 inch back spacing, but I did not actually measure them before I put them on.
Since I don't have much history on the car, I suppose these could be after market fenders and maybe the fit is not all it should be. Anyway, I think if I lift the rear up an inch or so, I will be ok, and maybe put in a good pinion snubber just to be sure I don't come down on the tire while driving. This is what lead to the 'add a leaf' question. Another option would be to shave off a little of the fender that comes so close to the wheel. Since the fender metal is bent toward the wheel at the opening, I doubt if you would even see it.
Comments?
