Author Topic: 15x8" Rallyes Rear with 275/60 BFGoodrich Radial T/As  (Read 4785 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: 15x8" Rallyes Rear with 275/60 BFGoodrich Radial T/As
« Reply #15 on: January 09, 2009 - 12:15:32 PM »
MIne hit in the wheel well itself. When I pulled the wheel I good see a nice shiny spot in where the tire rubbed.
1996 Dodge Viper GTS Coupe
Offline ShelbyDogg
« Reply #16 on: January 09, 2009 - 01:42:51 PM »
Mine sometimes rub on the outer wheelhouse too, if I try to run my rear-end too low. The outer wheelhouse curves in towards the center up inside the fender. too bad it isn't squared off inside there like a wheel tub, you'ld be able to get more tire in there. Maybe I'll do that when I put my new outer wheelhouses in.
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #17 on: January 09, 2009 - 03:38:57 PM »
Maybe I'll do the old stock car trick with a baseball bat, stickin and roll the car a head. Self clearing :woohoo: :woohoo:
Jackson from Toronto.
Offline Carlwalski
« Reply #18 on: January 11, 2009 - 02:06:11 AM »
IMO  you will be fine. Mine had the same gap before I re-tensioned the springs to raise the car a little. I couldn't get my fingers from about the knuckles forward past the middle of the top of the tyre. I have Edelbrock IAS Performer shocks that are a great shock, super stiff yet very comfy so this may have something to do with the limited rear travel play which would definitely help your concerns. Saggy shocks = more travel = more chance of rubbing and bottoming out. I have 15x8" with a 4-1/2" BS in the rear, same tyres and 15x7" with a 4-1/4" BS up front and never any rubbing issues. Having said that, not all cars are the same, someone else's JS23U car may not be the same width in the wheel housing as my JS23U car, they can and do vary.
 :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
