Fuel pump? What's everyone running?
Author Topic: Fuel pump? What's everyone running?  (Read 12931 times)
Offline 71chally416
    • The Streetwalker
Re: Fuel pump? What's everyone running?
« Reply #15 on: January 08, 2009 - 08:36:39 PM »
The biggest benefit IMO is getting the heat out of the gas. That's more imortant if you live in a hot climate.  :thumbsup:
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #16 on: January 08, 2009 - 08:39:43 PM »
That's what I was looking for!
Thanks for all the input so far, keep it coming! Always good to hear people's opinions on parts they've actually used!
 :thinkerg:
Put the electric pump in the tank it is quieter and stays cooler.
 still not sure I want to mess with the mounting and wiring. Not that I can't do it, I just dislike messing with electrical stuff.  :eek4:
its 2 wires  :o
Go Fast & Have Fun...
« Reply #17 on: January 08, 2009 - 08:40:15 PM »
I am useing the factory carter hp pump for a 440-6. I have no problems. But my engine isn't but maybe 400-425 hp. I havent made any passes at the track to give a true  rating useing mph vs weight vs et.  So im just really guessing hp level :2thumbs:
Offline hemiken
« Reply #18 on: January 08, 2009 - 08:41:01 PM »
I use a Carter HV fuel pump and have never had problems with them ever...... :2thumbs:
Offline Changin Gears
« Reply #19 on: January 08, 2009 - 08:43:56 PM »
I've always run a carter mech pump on a street car.
Another advantage to an electric is if your car sits long enough for the gas in the carb to evaperate, the pump will fill the carb without all that cranking.
« Last Edit: January 08, 2009 - 08:49:20 PM by Changin Gears »
Offline 71chally416
    • The Streetwalker
« Reply #20 on: January 08, 2009 - 09:15:03 PM »
I had a HP mechanical pump on my 440 chally back in the 80's. It sounded like a machine gun the first time I ran it at the track with open headers at the top of high gear (leaning out) so I upgraded the fuel system and never had that problem again.
I'm sure the mechanical pumps out now are better, but I'd still rather have an electric.
It sounds intimidating.  :naughty:
Offline 72bluNblu
« Reply #21 on: January 08, 2009 - 10:53:02 PM »
its 2 wires  :o
True, but it has to be wired into the ignition switch, so those 2 wires have to be strung into the cabin and under the dash, and then to wherever the pump ends up...
« Reply #22 on: January 08, 2009 - 10:55:58 PM »
1 wire really from the dash to the pump , them 1 short wire to ground
Offline 72bluNblu
« Reply #23 on: January 08, 2009 - 11:19:11 PM »
Also true. But my car isn't stock either, the power for my stereo is a wire thats soldered onto a fuse in the fuse block. Thanks PO! :villagers:  I know its really not that bad, I just haven't decided if I want to go there...The HV mechanical is sounding pretty decent. While my car may see the track a time or two, its mostly a street car. Although I do live in CA, so the temp thing can be an issue. I haven't had a vapor lock though since I re-routed the fuel line, somebody had strung a rubber fuel line right up next to the exhaust manifold  :22yikes:
Offline 71chally416
    • The Streetwalker
« Reply #24 on: January 08, 2009 - 11:54:05 PM »
A mechanical pump is bolted to the hot motor.
Offline challeng61
  • This is how it looked when I purchased my R/T 1978
« Reply #25 on: January 10, 2009 - 06:48:39 PM »
Holley GP110 Blue.  110 GPH  I Think a max 0f 14psi unregulated. Should be plenty.
Paul
70 R/T 440 Magnum Plum Crazy and 73 Dodge Challenger 340 4 speed ralley... Garage sale find.
Offline todd383
  • I'm a llama!
« Reply #26 on: January 11, 2009 - 09:04:34 AM »
I have always used carter mech. strip pumps, no problems , never did. All mopars that i have worked on have used 3/8 fuel line, and supported motors with over 550 hp. My challenger runs a 500+ hp 383 with this setup and have no issues at all :bananasmi
Offline the_engineers
« Reply #27 on: January 11, 2009 - 04:35:40 PM »
I have a Summit electric on rubber mounts.  You can hear it over my 2 1/2" TTI exhaust.  I'm changing out to a Mallory 110 in February.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #28 on: January 11, 2009 - 04:45:24 PM »
You won't believe that Mallory. You need a stethascope(sp) to know it's running.   :grinyes:
Offline 71chally416
    • The Streetwalker
« Reply #29 on: January 11, 2009 - 08:45:47 PM »
What does it do in the 1/4 mile?
