I also have a 530hp engine with HV Carter mechanical pump and 3/8 lines to a stock six pack hard fuel line. I ran high 11s like that.
I just upgraded the engine slightly with about another 20-30 HP so i upgraded the fuel lines too but have yet to test it to see what the car will do now.
I have just fitted a 1/2inch sender (was 3/8) and run 1/2 inch all the way to the pump.
At the pump I have opened out the inlet/outlets to take -8AN fittings and run -8 line to a large filter and regulator mounted behind the grille for cooling.
It then runs -8AN to the six pack where it branches into 3x -6AN lines that go directly to each carb.
I don't think I will have fuel delivery problems but i will let you know if I do.
PS
I hate electric fuel pumps and would only use one if really needed.
