hooking up my Keisler hydraulic master cylinder. Hmmmmm where to put it.
Author Topic: hooking up my Keisler hydraulic master cylinder. Hmmmmm where to put it.  (Read 1265 times)
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
The title about says it all.
Have you guys got any? I have thought of a few, but before I do I thought I'd ask you guys.
 :canada:
Jackson from Toronto.
Offline shawge
  • Zoiks!!
Re: hooking up my Keisler hydraulic master cylinder. Hmmmmm where to put it.
« Reply #1 on: January 08, 2009 - 05:23:38 PM »
I've seen it attached to the MC or the inner fender.
- Jerry
« Reply #2 on: January 08, 2009 - 07:18:52 PM »
it can only go one place in the clutch linkage hole under the pedal  :dunno:
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #3 on: January 08, 2009 - 08:19:20 PM »
yep  :iagree: are you thinking the reservoir ?  :clueless: I would go with putting it on the firewall  :thumbsup:
Go Fast & Have Fun...
« Reply #4 on: January 08, 2009 - 09:11:36 PM »
use the bracket off the master cylinder mount to mount the reservoir
Offline boydsdodge
    • Boydsdodge
« Reply #5 on: January 08, 2009 - 09:38:01 PM »
Oh ya, I ment the reservoir. Duhh just looking for ideas before I drill the virgin metal.
Offline somedaysoon
« Reply #6 on: January 08, 2009 - 11:05:47 PM »
Offline boydsdodge
    • Boydsdodge
« Reply #7 on: January 09, 2009 - 08:34:51 AM »
Is that the reservoir under your brake master? The aluminum cylinder?
Looks great, I have the stock plastic one from Keisler.
They now have the lines on top of the clutch master with a bleeder valve.
Offline somedaysoon
« Reply #8 on: January 09, 2009 - 09:59:58 PM »
 Yes it threads directly into the slave or master cylinder.
