Author Topic: Need a paint gun  (Read 4317 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Need a paint gun
« Reply #15 on: January 11, 2009 - 08:01:07 PM »
My friend uses a 1.4 for base and a 1.3 for clear. My brother has 1.3 in both of his.
1996 Dodge Viper GTS Coupe
Offline cwestra
« Reply #16 on: January 11, 2009 - 09:40:04 PM »
I used 1.3 for base and 1.4 for clear.  The smaller 1.3 nozzle helps atomize a little better than the 1.4, especially helps if your shooting metalic.
Corey - in Northern Indiana
Offline MoparCar
« Reply #17 on: January 11, 2009 - 10:44:02 PM »
Check out this site, forum (use the search engine) and the store. Great forum and site for autobody.
http://autobodystore.com/
Wes
Offline elitecustombody
  • Supra collector
« Reply #18 on: January 11, 2009 - 11:18:07 PM »
I personally wouldn't use anything smaller than 1.3,since I use only high solids clear which is fairly thick, but depending on what materials you spray,1.3 and 1.4 is very common and if you don't spend 8 hours a day in paint booth, they will do just fine, as far as choosing between high end guns,it's very hard as most of them do awsome job at atomizing the materials,some guns feel different in hands and are easier to control than others,so it's better to actually grab the gun and feel how well it conforms to your grip, also keep in mind about the size of the cup,alot of the HVLP guns will put out so much material in so little time that filling it up every 5 minutes gets old pretty quick
Stefan B
