Author Topic: Pertronix Flame Thrower Distributor  (Read 1369 times)
Offline 73440cuda
« on: January 11, 2009 - 12:53:05 PM »
I'm installing the pertronix flame thrower distibutor and i have some questions. The instructions say to connect it directly to the coil, what do you do with the orignal wires that went from the original distributor to the ECU?  Is the ECU still needed?  Also do I still need the ballast resistor?
Offline 71chally416
    • The Streetwalker
Re: Pertronix Flame Thrower Distributor
« Reply #1 on: January 11, 2009 - 01:08:21 PM »
When all else fails, follow the directions you got with the disytributor. If you bought it used go to the website and get them.  :thumbsup:
Offline 73440cuda
« Reply #2 on: January 11, 2009 - 01:12:08 PM »
The instructions are very vague, All it says is to connect the red wire to the positive side of the coil and the black wire to the negative side of the coil.  It does not say what it replaces or what does not need to be connected.
« Reply #3 on: January 11, 2009 - 01:36:56 PM »
Pertronics Do not Hook to the coil Positive , if you do the car may not start or run properly
 if you Read the instructions it says to connect the red lead to 12V , the coil is 8 volts , you need to connect the pertronics to the blue 12v switched wire at the ballast for it to work correctly
 yes you need the ballast resister still
