Author Topic: Parts Inter-Change 318/904 to 340/727?  (Read 2990 times)
Offline challengermaniac
« on: January 14, 2009 - 11:43:13 PM »
Hi guys,
I have a 1970 Challenger with a 318/904 that I am going to pull out and install a 340/727.
Need to know which of these 318/904 parts are interchangeable/transferable over to the 340/727:
* 318 Water Pump
* 318 Power Steering Pump
* 318 Stock Exhaust Manifolds
* 318 Auto Accelerator Bracket
* 318 Alternator
* 318 Fuel Pump
* 318 Starter
* 318 Engine Mounts
* 904 Bell Housing
* 904 Fly Wheel
Any other parts on the 318/904 you can think of that will also transfer over nicely to the 340/727?
Thanks, Charlie
ps: any recommendations you can make of a publication/book I should read up on to gleam all of the info on a 318/904 to 340/727 swap?
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Parts Inter-Change 318/904 to 340/727?
« Reply #1 on: January 14, 2009 - 11:52:54 PM »
All of those parts will interchange, but I would not use the 318 manifolds as they are really restrictive and probably smaller ports. and there is no removable bellhousing on the 904 or 727, but the bolt pattern is the same for the 2 as long as they are both small block transmissions. The accelerator bracket may need modification, but not sure.
1996 Dodge Viper GTS Coupe
Offline 426HEMI
« Reply #2 on: January 15, 2009 - 12:23:49 AM »
It is a pretty straight forward swap.  As long as both are LA engines I do not see a problem.  Would have to agree on the exhaust manifolds they would have to be ported to be used.   The bracket may have to be switched for the Auto Accelerator Bracket for a 4bbl if that is what you are going to have on your car.  Everything else will interchange.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #3 on: January 15, 2009 - 01:36:09 AM »
Left engine mount is also different , it could be shimmed modified or replaced to solve the issue
 also the torque converter will not swap & depending what converter is used you may need a different flex plate to attach the 2 as there are 2 different diameters / bolt patterns
Offline 426HEMI
« Reply #4 on: January 15, 2009 - 06:02:19 AM »
Opps my bad was not thinking completely on that.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline heminut
« Reply #5 on: January 15, 2009 - 09:54:03 AM »
I believe the 727 is longer than the 904 also, and if so you will have to shorten the driveshaft.
1970 5.7 Hemi Cuda
Offline GoodysGotaCuda
« Reply #6 on: January 15, 2009 - 10:03:31 AM »
cooler lines any different?
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 72hemi
« Reply #7 on: January 15, 2009 - 10:08:49 AM »
Cooler lines are the same. The driveline is 4 inches shorter and the yoke is a different spline.
Offline resq302
« Reply #8 on: January 15, 2009 - 12:23:01 PM »
My dad is going to be putting 340 HP exhaust manifolds on his 318 and changing over to 340 heads.  Would he need to change the left motor mount also?  What is the reason for a different motor mount?
Offline 72hemi
« Reply #9 on: January 15, 2009 - 12:35:50 PM »
No he won't have to change. No idea why there is a difference.
« Reply #10 on: January 15, 2009 - 12:50:28 PM »
 :iagree:
if he is not changng the block the mount doesn`t need to be changed either
 the left mount is different , only Mopar knows why
 the driveshaft & slip yolk will need to be changed as well as above have said
