Author Topic: Will 70 Challenger grills fit on a 73?  (Read 1008 times)
Offline lemming303
  • San Antonio, TX
« on: January 16, 2009 - 06:15:53 PM »
The whole assembly, not sure what you call it. Head lights and grill, the entire section between both fenders. I'm asking because I really like the 70 or 71 grills compared to the 73 round ones. My car is by no means going to be original so I'm not worried about that.
Kevin
73 Challenger Rallye - first project
Re: Will 70 Challenger grills fit on a 73?
« Reply #1 on: January 16, 2009 - 06:22:18 PM »
There have been a few threads about this over time. It will take some doing on your part. Cutting...welding...
You see, the front fenders are different, so is the header panel that holds the grill. If you get a pair of 70-71 front fenders, then this might get easier, but more expensive.
Offline wally426ci
    • maryland mopars
« Reply #2 on: January 16, 2009 - 06:25:18 PM »
Im with Stu... uhhhh, oh wait a minute...  :roflsmiley:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #3 on: January 16, 2009 - 10:50:06 PM »
as stated above the fiberglass grille hold the headlights so when that is removed you need to install steel headlight buckets onto the fender to hold the lights , also the front fender trim doesn`t work , using 70-71 fenders is one way to solve the issues
Offline lemming303
  • San Antonio, TX
« Reply #4 on: January 16, 2009 - 11:23:43 PM »
OK thanks yall. I guess I'll just leave it alone and buy another Challenger later on in life!
Kevin
« Reply #5 on: January 17, 2009 - 01:02:21 AM »
Or you can buy a front cap  :2thumbs:
« Reply #6 on: January 17, 2009 - 01:19:23 AM »
repopped fenders are not huge $$ & 70 grilles are around because they were metal Not plastic like most years
