Author Topic: Keisler pilot bearing - difficult to install?  (Read 1833 times)
Offline shawge
  • Zoiks!!
« on: January 18, 2009 - 11:13:18 PM »
For those with Keisler 5-speeds, how difficult was the pilot bearing install?  Does the bearing need to be pressed in or should it just drop right in?
- Jerry
Re: Keisler pilot bearing - difficult to install?
« Reply #1 on: January 19, 2009 - 03:56:25 AM »
they are a friction fit so you need to tap them into place
Offline shawge
  • Zoiks!!
« Reply #2 on: January 19, 2009 - 01:06:40 PM »
Thanks CP.   How forceful can the tapping be before I break something?  I guess I'm concerned about damaging the thrust bearing.
- Jerry
« Reply #3 on: January 19, 2009 - 03:09:42 PM »
I would use a socket or similar so the force is on the edge of the brg
Offline Oldschool
  • Member Since 9-05-06
« Reply #4 on: January 19, 2009 - 03:17:05 PM »
We used to freeze the pilot bearings for a few hours.  The colder the better. This "contracts" the metal slightly allowing a little easier install.  Then they warm up, expand and fit just right......     :thumbsup:
« Last Edit: January 19, 2009 - 03:29:25 PM by Oldschool »
Ken  --  In Georgia
Offline Mopar73340
« Reply #5 on: January 20, 2009 - 03:52:17 PM »
I just tapped mine in. It wasn't real tight, just tight enough so you had to tap it in lightly with a hammer.
Offline IMNCARN82
  • LeDZeP
« Reply #6 on: January 24, 2009 - 11:09:09 AM »
yup.  I like the freezer idea too.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline go-fish
« Reply #7 on: January 24, 2009 - 07:49:34 PM »
Mine went right in with a few taps.
Offline shawge
  • Zoiks!!
« Reply #8 on: January 26, 2009 - 01:06:33 PM »
Thanks to all who responded.
I did have to put the bearing on a lathe and cut it down some.  I put the bearing in the freezer overnight and heated the crank end with a heat gun on low prior to install.  Using a little 30wt oil as lubrication, I used a large socket and eventually got the bearing to seat after about 30 taps.
- Jerry
