Author Topic: I need pic of rear wheel well front lower.  (Read 2275 times)
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
Re: I need pic of rear wheel well front lower.
« Reply #15 on: January 19, 2009 - 10:12:20 PM »
Thanks Tom, they help alot.
Jackson from Toronto.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #16 on: January 19, 2009 - 10:18:18 PM »
Tough to get good pics of the orange up close.
Tom
What are you needing to check?
Tom
Offline boydsdodge
    • Boydsdodge
« Reply #17 on: January 19, 2009 - 10:45:30 PM »
I wanted to make sure that the patch panel had the correct radius and where the panel ends as it rolls upward.
I also need to know where the rocker panel/1/4 pinch ends, as in how far into the wheel well it goes.
Offline pink panther
« Reply #18 on: January 20, 2009 - 09:31:16 AM »
here is some i took for you
« Reply #19 on: January 20, 2009 - 09:32:18 AM »
another
« Reply #20 on: January 20, 2009 - 09:33:29 AM »
and another
« Reply #21 on: January 20, 2009 - 09:34:23 AM »
more
Offline boydsdodge
    • Boydsdodge
« Reply #22 on: January 20, 2009 - 09:34:43 AM »
Perfect timing, I am just fitting the patch now. thank you
« Reply #23 on: January 20, 2009 - 09:36:18 AM »
another
« Reply #24 on: January 20, 2009 - 09:37:37 AM »
more
Offline boydsdodge
    • Boydsdodge
« Reply #25 on: January 20, 2009 - 09:38:46 AM »
I am sorry, I don't want to be ungrateful but I need it from a lower angle, like how I took my pic as an example.
« Reply #26 on: January 20, 2009 - 09:41:17 AM »
no problem, I can take more antyway you want them.
