Author Topic: speedo check  (Read 972 times)
Offline CUDA JAS
  • vroooooom!
speedo check
« on: January 19, 2009 - 08:53:09 PM »
I am switching over to a rallye cluster this winter.  I want to make sure the speedo is working, unlike the one in my standard cluster (makes a racket and bounces at anything over 50 MPH) :pullinghair:.
How do you test a speedo out of the car.  Is it possibel to lubricate the speedo as well?
Jas
74 'cuda 360/727
Just call me a gearhead!
Offline quapman
    • Auto-Grip on Facebook
Re: speedo check
« Reply #1 on: January 19, 2009 - 09:04:14 PM »
I cut off an old speedo cable and put it in a cordless drill. Make sure you run it BACKWARDS.
Steve
Offline BIGSHCLUNK
Re: speedo check
« Reply #2 on: January 19, 2009 - 09:55:07 PM »
We have a real good guy here (Milwaukee) that does speedo's/tach's if you need help.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Re: speedo check
« Reply #3 on: January 20, 2009 - 01:31:34 AM »
the bouncing could be the cables fault as well  , it is possible to open the speedo & clean & lube the moving parts
Offline CUDA JAS
  • vroooooom!
Re: speedo check
« Reply #4 on: January 20, 2009 - 09:55:03 PM »
I plan to replace the speedo so, I hope the bouncing is not the cable...all though that is not to bad to replace.  :sly:
Is it possible to lube the speedo without pulling it all apart...not sure I am up for that, or really know how to do it.  :1zhelp:
Jas
74 'cuda 360/727
Re: speedo check
« Reply #5 on: January 21, 2009 - 01:05:12 AM »
not really you need to disassemble it , it is easy to do though , you need to remove the clear face plate & undo 2 scews from behind & the guage slips right out
Offline heminut
Re: speedo check
« Reply #6 on: January 21, 2009 - 09:37:17 AM »
You should also lube the cable too, as Chryco said it could cause the bouncing if it's dry. You can pull the inner cable out of the housing from the speedometer end and lube it with white lithium grease. Just coat the cable with the grease and slide it back into the housing. I've cured speedo bounce several times doing this.
1970 5.7 Hemi Cuda
Offline CUDA JAS
  • vroooooom!
Re: speedo check
« Reply #7 on: March 30, 2009 - 09:35:45 AM »
Stupid question,
What shoduld I use to clean and lube the moving parts?
jas
74 'cuda 360/727
