Author Topic: Road lamp switch location?  (Read 1026 times)
Offline r15303
« on: January 20, 2009 - 12:03:20 AM »
Forgive the ignorance but I'm putting a 71 Cuda back together that came in pieces and I need to know where the road lamp switch and the map lamp switches are mounted. can anyone help with pictures/  :1zhelp:
Offline ebodycrazy4ever
Re: Road lamp switch location?
« Reply #1 on: January 28, 2009 - 09:50:54 AM »
Standard or Ralley dash? If its a standard, here is a picture of one from my files. I don't have a pic for a ralley location but on ralley dashes it goes under the lower left side of the dash lip frame on the left. If I find a pic I will post it here.
But here is a ROAD LAMP switch located on a 71 Gran Coupe standard dash cluster....
« Reply #2 on: January 28, 2009 - 09:53:13 AM »
Here is 'my 70 Gran Coupe' dash, now you have to look REAL close on the lower frame left side, look below the heater panel left side corner, I'm sure you can see it if you take some time....
« Reply #3 on: January 29, 2009 - 08:35:54 PM »
map light goes under the ashtray area just to the right a bit , the hole should already be there
Offline r15303
« Reply #4 on: February 05, 2009 - 02:42:50 PM »
Thanks Guys.  Got it installed and working!!
