More A-833 questions
Author Topic: More A-833 questions  (Read 2903 times)
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« on: May 26, 2004 - 12:49:19 AM »
I have a cast-iron short tail A-833 with an input bearing retainer measuring a little over 5.1 inches, which would make it an OD, I believe.  I was under the impression that all OD A-833s were aluminum.  Is there a way I can tell for sure?
The next question, is it possible and how hard is it to swap a '70 and later long tail shaft onto/into it?  Anyone done this before?
1970 Dodge Challenger
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
Offline Pistol Gripper
Re:More A-833 questions
« Reply #1 on: May 26, 2004 - 05:01:02 AM »
Rabid,
Here's a good article:
http://www.slantsix.org/articles/4-speeds/ODA833fourspeed1.htm
Hope there's some info you can use.
P.G.
O ne
B ig
A $$
M istake
A merica
« Reply #2 on: May 26, 2004 - 02:28:11 PM »
the early ODs were cast not alum , what you have is much harder to find , , a short tailshaft A body cast iron od 833, you will need  the long main shaft & long tailhousing to switch it to a E body application , I have both pieces if you need them
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #3 on: May 26, 2004 - 06:46:29 PM »
Thank you for the link, I have checked it out.
Chryco, I would be very interested in the tail and main parts.  I'm sending you an IM right now!
Is swapping tailshafts something I'll need a press to do?  I have the tranny partially disassembled right now, and the tailshaft seems to be caught on something, but I don't see a clip or anything.
WaywardGarage.com
« Reply #4 on: May 26, 2004 - 07:43:08 PM »
no you do not need a press ,the OD is difficult to assemble & disassemble, you need to pull out the front input shaftas far as possible , rotate the tailhousing 180*  pry the counter shaft back with a small screwdriver & remove the key then tap the shaft forward to drive out the frost plug in the front of the case & slide a dummy shaft into the counter shaft to retain all the rolller brgs & drop the counter shaftinto the bottom of the tranny case [I can get you an exact measurement for the needed dummy shaft, it can be made from heater hose or conduit ]   & put the front syncro forward to remove the tailshaft & housing as 1 unit , then on the top of the rear housing there is a window where you need to expand a snap ring to remove the rear brg & main shaft, from there you need to remove snap rings & swap all the gears syncros & brg to the longer main shaft a reassemble the tranny
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
Re: More A-833 questions
« Reply #5 on: July 02, 2004 - 02:48:31 PM »
Alright!  I got my tailshaft!!   :D  I have to thank Neil (Chryco Psycho), he is a top rate guy, and the parts were all beautiful!   ;D
Can't wait to get this transmission put all back together.  It'll will give me an incredibly steep first gear (3.09, similar to a GM 700r4's 3.06 first gear), and a 149 MPH @ 5500 RPM with my current 3.91 rear-end.  With 3.23s the top speed goes up to 180 MPH @ 5500 RPM.....  ;)
Anywho, I got the tranny disassembled, and while trying to remove the countershaft, I used a section of rubber hose to hold the roller bearings from coming out, then I screwed something up (the rubber hose was too small...  DOH!), and all the roller bearings fell out.     :o  I suppose I learned something by doing this....  >:(
Is it this hard to fix?  How do I go about re-installing all those eight billion little roller bearings?   ???
WaywardGarage.com
« Reply #6 on: July 02, 2004 - 08:36:20 PM »
72 rollers to be exact
 you need a dummy shaft the correct length & diameter to go inside then use a thick grease a pack them carefully , into the counter gear use 18 rollers then the spacer ring 18 more rollers & the second spacer ring from each end , put the best thrust washer at the rear or replace the bad one
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #7 on: September 08, 2004 - 02:01:50 PM »
I was swapping tailshafts and tailshaft housings, putting the E-body long tail shaft into an early cast-iron A-body OD four speed case, and ran into a problem.
The original A-body mainshaft had a bearing at the end of it, and the longer B/E body tailshaft end is bigger and will not let me put the A-body's bearing on it.  Please see the picture below.
A.  The long tailshaft, out of an E or B body, with all the swapped on gears and such.
B.  The bearing from the A-body tailshaft, which fits shaft C, but not shaft A.
C.  The short tail, from a A-body OD tranny.
I sent an email over to the guys at Passon performance, and they're stumped too.
Quote
Scott,
We have built literally hundreds of these and I have NEVER seen something
like this before.  I need a picture of the A Body shaft in its entirety.
Also, the gears that are on the long shaft, are they from the A Body shaft?
Please take a picture of the inside of the input shaft on the A Body
transmission.  I am starting to think that someone retrofitted this bearing
in because these transmissions never used a raced type bearing on the tip of
the shaft like is shown in the picture.  You can call me as well if you see
fit.
Thanks,
Jamie
I'm going to call Jamie back, I just want to throw this up here to see what Chryco and the rest of everyone thought of this.
WaywardGarage.com
« Reply #8 on: September 09, 2004 - 02:22:02 AM »
I have not seen that before either , usuall there are rollersa inside the drive pinion , not a roller brg , possibly the front of the mainshaft was damaged so it was machined down & a brg was fitted
