Author Topic: mopar action brake issue  (Read 5059 times)
Offline Katfish
  • 70 Challenger
Re: mopar action brake issue
« Reply #15 on: January 24, 2009 - 02:06:24 PM »
i think i have solved the problem i found a 72 challenger in the junk yard that has disc brakes .... so if the guy will come off of ti i am gonna buy them... and i checked at advance i can get new caliper pads and bracket for 52 bucks :cooldancing: :cooldancing:
I bought eveything for my Challenger at local Advanced Auto. If you order online, you'll get free shipping.
raybestos w/pad RC4103/4 $36.00
78 charger (slider)
outer bearing BR2 $6.00
78 charger
wearever rotor YH141132 $52.00
78 charger
dorfman banjo bolt 13938 $5.00
inner wheel bearing BR17 $8.00
77 charger
inner seal 19500 $2.00
77 charger
raybestos hose 4536755 $15.00
76 duster
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
« Reply #16 on: January 24, 2009 - 06:00:03 PM »
i got the spindles,dust shild,rotors,calipers,bracket for caliper off an 72 chally ... do i need to get the upper and lower contorl arms to have disc brakes on my 72 chally ?????or is that all i need .... thanks for list katfish
« Last Edit: January 24, 2009 - 06:05:53 PM by WVUFELLA »
Offline Changin Gears
« Reply #17 on: January 24, 2009 - 06:12:27 PM »
you don't need to get the control arms, they are the same.
Offline Katfish
  • 70 Challenger
« Reply #18 on: January 24, 2009 - 07:13:13 PM »
Please note **** The parts I listed are for the 11.75 brakes
Offline WVUFELLA
« Reply #19 on: January 24, 2009 - 07:27:45 PM »
i th9nk that is whati have but not sure .... guess i need to throw a tape them to fid out... i hope big rotors look nice
Offline mrcuda
« Reply #20 on: January 24, 2009 - 07:46:55 PM »
I think that I missed most of this story, but you guys might be able to help me too. I have a 71 challenger with the original disc brakes. I was thinking of converting it to the later setup, but really like the idea that these are original to the car. Anybody know where you can get the rotors for a fair price without spending a billion bucks. Thought that advance has them for 80 something, and autozone for 77. Anyone know of a better price?
Offline mrcuda
« Reply #21 on: January 24, 2009 - 07:51:49 PM »
Anybody ever use those Dr. diff adapters? Do you know if they fit the early  e-body spindles?
Offline WVUFELLA
« Reply #22 on: January 24, 2009 - 07:54:01 PM »
 i am new to the disc brake game ... i had [planned on using advance auto...jus cuz it is easy
Offline Katfish
  • 70 Challenger
« Reply #23 on: January 24, 2009 - 08:02:11 PM »
That's 1 of the advantages of the later disc rotors, much cheaper because they were used on everything till the 80's.  I've seen the 11.75 rotors as low as $30.  I don't know how much the adapters cost, but I'd bet it wouldn't be worth it, if cost is the factor.  I'm guessing they have to be $25-$50.  If you don't put many miles on your car just get the $75 rotors and your good to go for another 10yrs.
Offline mrcuda
« Reply #24 on: January 24, 2009 - 08:10:38 PM »
I think I have an extra set of 73 disc setup from a 73 barracuda, but was going to use it on my 70cuda, but can you just put the 11.75 rotors on the 73 spindles without changing anything?
« Reply #25 on: January 24, 2009 - 08:12:09 PM »
You have to change to caliper adapters  to the 11.75" also.
Offline mrcuda
« Reply #26 on: January 24, 2009 - 08:16:18 PM »
Thanks for the info, but anyone know who sells the caliper adapter and the price?
Offline Katfish
  • 70 Challenger
« Reply #27 on: January 24, 2009 - 08:20:25 PM »
Offline WVUFELLA
« Reply #28 on: January 25, 2009 - 10:57:16 AM »
one more question for i put new ball joints in my car(72 chally) which currently has drum brakes.... since i dont need the Upper and lower control arms off the the 72 disc brake donor car... is it safe to say i can use ball joints already insalled on my car and jus bolt the spindle to it??
« Reply #29 on: January 25, 2009 - 11:03:56 AM »
For the lowers, if there tight, I say go ahead.  For the uppers, you might damage the joint/seal, depending on how you seperate them from the old spindles.  Pickle fork is pretty brutal.
But, you need to do an alignment anyway, so why not do them all.
« Last Edit: January 25, 2009 - 11:07:10 AM by Changin Gears »
