Author Topic: Stress cracks top of windshield pillar to roof joint  (Read 1896 times)
Offline femtnmax
« on: January 22, 2009 - 09:42:09 PM »
I have not yet sanded the paint off, but the crack is visible, just a hair line width, wrapping around the outer 3 sides of the pillar.  No damage to unibody, original front fender and rear quarter.  Door has been replaced in the past.  The welds along the window, windshield, and inner pillar all look ok, none are missing.   Any comments on best repair would be appreciated.
Body also has rear quarter panel cracks at the aft lower quarter window, which from what I read is common.  I'm replacing both rear quarters so no problem there.   Car is 318 74 challenger, no big cubes.  Thanks.
Phil
Alaskan_TA
Re: Stress cracks top of windshield pillar to roof joint
« Reply #1 on: January 22, 2009 - 09:51:00 PM »
Since the paint is still on, is the crack just in the body filler that covers the actual welds where the roof meets the pillars? If so, that is common.
Offline elitecustombody
  • Supra collector
« Reply #2 on: January 22, 2009 - 10:48:41 PM »
please post upclose photos,
Stefan B
Offline MoparCar
« Reply #3 on: January 23, 2009 - 07:10:08 AM »
Mine had the same thing. After I media blasted the car, it was actually cracked at the seam. It's lead there on mine so I'm assuming it's a factory leaded seam. Usually lead won't do that, but it did on mine also.
Wes
Offline the_engineers
« Reply #4 on: January 23, 2009 - 12:00:38 PM »
 :useless:
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #5 on: January 23, 2009 - 04:08:43 PM »
This is why sub-frame connectors or torque boxes are a good idea, even if your car is just a cruiser.
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #6 on: January 23, 2009 - 07:42:30 PM »
Since no-one has actually answered your question, let me try. First, I might be tempted to get some factory frame measurements (from a factory book or Mitchells or another car) and measure your frame points. At the very least measure cross-ways from front and rear-most fender bolts to make sure the unibody is square. Seems to me if it's cracking at all roof attachment points, and the door was replaced you want to rule out a hard hit. If it all checks out, grind the lead filler to the base metal and ensure there's no rust down there. If there is or not, I'd treat it with Metal Ready (or some Phosphoric acid prep) and then fill er back up with more lead or bondo. (Make sure you don't sand lead finely - it's toxic dust like that!). good luck.
Offline femtnmax
« Reply #7 on: January 23, 2009 - 09:11:51 PM »
Here are some photos.  Sorry for the delay.  Good ol' Bresnan internet.
Phil
Alaskan_TA
« Reply #8 on: January 23, 2009 - 09:25:36 PM »
As I suspected then. Here is a photo of one without the filler in it, whether the seam was covered with filler or lead you can remove it with a small wood chisel.
Offline femtnmax
« Reply #9 on: January 23, 2009 - 10:47:40 PM »
Only the one pillar has a crack in it.  I'll remove the lead filler and inspect the structure.  Thanks to all.
Phil
Offline ShelbyDogg
« Reply #10 on: January 27, 2009 - 12:02:29 AM »
Use a torch and a brush, that lead will come right out of the joint. Weld it up to make it stronger.
