Author Topic: 1000 HP engine setup?  (Read 36515 times)
Offline gkring
Re: 1000 HP engine setup?
« Reply #30 on: January 27, 2009 - 01:46:00 PM »
If you could build 950hp to run 300miles out of 18 galons, I would be ringing you up tommorow to order 1  :icon16:
Been done many times over. My last car sold to get my convertible was a 1987 Buick Grand National. 252 cubic inch V-6 with single big turbo. Got 19 miles per gallon on long trips, but burned 2 gallons every quarter mile pass. 3750 pounds with me in it and it ran 9.0 @ 150 in the quarter. Expensive motor, mostly Busch Nascar series internals, Crower this and that, roller cam bearing, titanium valves, etc. Cruise control, A/C, power steering, etc. On the street I ran pump gas and it would run easy 10.0 on it and drag radials. I never pushed it to the edge on pump gas or race gas, but I could push it further safely on the good stuff. When I do it again it will be with a bigger motor and less dependence on the turbos. Instead of 4 hp per cube with smaller cubes maybe something in the 2-2.5 hp per cubic inch. Easier and cheaper to build, last slonger, and is more street friendly if you are just driving it. Any way you slice it they are race cars you can drive on the street if you want to and can get away with it. Calling them street cars or race cars is just an ego thing.
Greg
1970 Barracuda driver
nivvy
« Reply #31 on: January 27, 2009 - 03:42:04 PM »
To me, the great "street car" equalizer is pump gas.  If the car meets lighting, sound, horn, wipers......... that's one thing. It could be a street car.  If it meets the above and runs strictly on gas available at any commercial pump, (93 octane) then it qualifies as a street car.  It would be tough to build a 1000 HP N/A car that will make those numbers on pump gas.  I am talking pump gas with zero octane booster or mixing with race gas.    :2cents:
I completely agree....  :working:
Offline The Cuda Man
« Reply #32 on: January 27, 2009 - 05:01:52 PM »
I think the problem most of us have that recommend against it is the combination of "easiest" and "cheap".
I dont think I clarified my point well enough in my first post. I understand that building an engine of this caliber will never be "cheap", hence why i said cheapest. But, it is also true that it is possible to obtain that much power through a less expensive setup. The same applies when I say "easiest" as well, there are certainly easier setups than others.
Hopefully this makes sense, and sorry for the confusion.
Sam
« Last Edit: January 27, 2009 - 05:10:42 PM by The Cuda Man »
nivvy
« Reply #33 on: January 27, 2009 - 05:33:50 PM »
4 barrel with power valve and adjustable secondaries outside the carb ...  :bigsmile:
wagesofsin
« Reply #34 on: January 27, 2009 - 06:31:17 PM »
ill stick with the 1k cfm carb pro form made for me, thank you.
john
oh, and sam, i fully understand what the threads all about buddy. i was goaded into posting my motor by a certain somebody who shall remain nameless. i thought it would be in poor taste, and wouldnt fit in.
but it is what it is, and i can drive the car on the street.
im outta here, you guys keep fightin about street this and whatever. its a car, i built it, so i drive it, wherever i want. haha,
i got work to do...
 :working:
john
« Last Edit: January 27, 2009 - 06:52:09 PM by wagesofsin »
nivvy
« Reply #35 on: January 27, 2009 - 11:39:10 PM »
wages that is a nice mill regardless........  :ylsuper:
Offline 71chally416
    • The Streetwalker
« Reply #36 on: January 28, 2009 - 02:21:18 AM »
The trouble with Turbo cars, at least in drag racing, is they are horribly inconsistent. Any Jensen runs one in our ProMod club and he'll do a 6.30 followed by a 7.00. They still haven't figured out how to get the boost consistent from pass to pass.  :grinno:  That and a smart driver racing a turbo car will quickly light the stage beam and not give a turbo car time to spool the turbo.  :naughty:
« Reply #37 on: January 28, 2009 - 09:23:47 AM »
john
i got work to do...
 :working:
john
 :cheers:
Offline ntstlgl1970
  • T a c o c a t
« Reply #38 on: January 28, 2009 - 08:58:04 PM »
"What if we remove the turbos and say make 750-850 N/A running on dual Quad double pumper Holleys (or single 4 barrel if its better)? (babying it, never driving on the secondary barrels). Or the turbos is the only way to get mileage + big horsepower. (i hate turbos)"
Turbos are about the only way to make that kind of power and have somewhat decent gas mileage. Even if you were to build something that makes 750-850hp N/A it would require a pretty aggressive roller cam which would mean lots of maintenance. Depends on what you want to do.
nivvy
« Reply #39 on: January 28, 2009 - 09:04:54 PM »
my solid roller isnt too aggressive  :bigsmile: to date I only broke 1 k motion k 1000 spring..... at the track  :scared:
« Last Edit: January 28, 2009 - 09:06:29 PM by StRoKer »
wagesofsin
« Reply #40 on: January 28, 2009 - 09:14:53 PM »
what do you consider aggressive? my sons running a 714 on the street, and we adjust it once a year. and thats daily driving.
john
Offline ntstlgl1970
  • T a c o c a t
« Reply #41 on: January 28, 2009 - 09:16:44 PM »
As was mentioned before too, depends on what the OP means by "street car". Something that you can drive to the track instead of trailering or something you can drive 300 miles to a car show and not worry about it.
wagesofsin
« Reply #42 on: January 28, 2009 - 09:20:54 PM »
i just said it was a daily driver!!
geez, no wonder why theres confusion, its some that can, and some that aint got a clue.
nivvy
« Reply #43 on: January 28, 2009 - 09:24:37 PM »
closest track to me is about 1.75 hours away... im not paying for gas  :lol2:
Offline NoMope Greg
« Reply #44 on: January 28, 2009 - 09:25:40 PM »
That was uncalled for.  :eek7:  That's not in the spirit of this board to get into name-calling, indirect or not.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
