1000 HP engine setup?
Author Topic: 1000 HP engine setup?  (Read 36513 times)
Offline vs2
Re: 1000 HP engine setup?
« Reply #60 on: January 31, 2009 - 01:09:20 PM »
VS2... keep us updated.. I am going F1R my next setup also...  :thumbsup: may need some help.....  :working:
Will do. Been over 3 years to this stage. I'll put up a thread when shes all done.
Offline ntstlgl1970
  • T a c o c a t
« Reply #61 on: January 31, 2009 - 02:41:00 PM »
sounds like you'll have a lot left in it too at 10psi, that's cool.
Offline vs2
« Reply #62 on: January 31, 2009 - 03:52:28 PM »
I don't know what the numbers will be its just what I've been told. Engine has been built with a lot of consideration. There will definately be heaps of torque and I won't run more that 80% of its potental no matter what the hp to the wheels is. It will be a street/show car and I want it to last. If it ends up been 7/8/900 hp at 10 psi so be it.
Basic Spec.:
1.   Keith Black 588ci  alloy street Hemi block – 6 bolt mains
2.   Ray Barton TMD roller rockers
3.   Billit  solid lifter cam with tool steel lifters– intake 512 / exhaust 593 / 250 duration
4.   4.625 stroke scat crankshaft
5.   Stage V heads
6.   Billet manley steel ‘I’ beam rods
7.   JE forged 8-1 pistons
8.   Miloden gear drive
9.   Miloden oil system with external entry and swinging pick-up
10.   F1-R Procharger with water/methanol injection
11.   FAST fuel injection
12.   727 competition torqueflite with gear vendors O/D
13.   Dana 60 with powerlock – shortened 150mm
14.   2 ¼” TTI headers
15.   B&M black diamond shifter
16.   Wilwood superlites - 11 ¾ front / 13 ¼ rear.
17.   American Racing Torque thrust II – 12x15 rear / 8x15 front
18.   Caltracs rear suspension
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #63 on: January 31, 2009 - 08:02:16 PM »
Here's a 632 CID pump gas motor that makes 915 HP @ 6100 RPM and 882 ft/lbs of torque @4500 RPM. How's that for a N/A pump gas motor??? WOO-HOO baby!! And it's for sale on Moparts if you've got a cool $15,500.00. I'd say not too bad for getting a motor that's darn close to 1000HP for under 20K!! How bout them apples!! :burnout:
        Matt B.
Matt
Offline vs2
« Reply #64 on: February 02, 2009 - 08:13:54 PM »
Here you go Sam.
Offline The Cuda Man
« Reply #65 on: February 02, 2009 - 08:55:49 PM »
Looks like your going to have one hell of a ride there! Thanks for the pics and keep me updated on your progess.
:cheers:
Thanks,
Sam
Offline TROUBLE987
« Reply #66 on: April 16, 2010 - 10:07:43 PM »
Basic Spec.:
5.   Stage V heads
so how much do you have tied up in the motor,if you dont mine me asking?
