Author Topic: Name / Where do I get?  (Read 970 times)
Offline Burpin Chunks
  • http://mikescuda.net/cuda-challenger/burpin_chunks
« on: May 26, 2004 - 09:27:34 PM »
What is this called and where do I get one.
It is the Rubber boot that sealed the gas filler pipe and the gas tank. Mine Leaks. Maybe once I get it fixed I will get 8 miles per gallon instead of 6.
[attachment deleted by admin]
Re:Name / Where do I get?
« Reply #1 on: May 26, 2004 - 09:28:15 PM »
and a close up
« Reply #2 on: May 26, 2004 - 09:29:04 PM »
One last thing...... Any suggestions on the best way to replace it...... Do I have to drop the gas tank?
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: May 26, 2004 - 11:09:20 PM »
Go to the Paddock at this link.
http://www.paddockparts.com/Paddock/assets/html/homepage.asp?URLCheck=1
Then click Dodge/Plymouth on the left. . . go to fuel/gas tanks and you should find what you need.  I believe it said that the seals won't be available until after June 4. . . but thats not to far away.  You could also check with Year One . . . they might have them in stock.  I think they call it a filler neck seal.  I would drop the tank.  It looks like you need the seal for your trunk floor also??
http://www.yearone.com/serverfiles/fbshopmain2.asp?cat=1
Hope that helps!!
4C
« Last Edit: May 26, 2004 - 11:15:49 PM by 4cruzin »
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #4 on: May 26, 2004 - 11:14:29 PM »
Don't forget to check with your local Chrysler dealer as a lot of these are still available. I changed mine a couple of years ago now but got it from DC. Warehouse had stock and got it overnight.
2013 Tige' RZR 343hp
Offline 360 'CUDA
« Reply #5 on: May 26, 2004 - 11:34:18 PM »
I got my last one from Tom at R/T Specialties
"cheap"
http://rtspecialties.net/~rtspec/
Offline BIG MIKE
« Reply #6 on: May 27, 2004 - 02:31:56 AM »
Behind the license plate bracket the filler neck has a couple of screws, take them out then spray some lube around the neck/tank meet then start to wiggle, and twist working it out.
I think it will be easier that way. With the angle that the filler neck goes in the tank makes it more of a pain than the above.
if you need pictures i could get them for you.....let me know, i could post them late tomorrow.
« Reply #7 on: May 27, 2004 - 07:50:43 AM »
Why do you say that?
« Reply #8 on: May 27, 2004 - 10:14:09 AM »
I called my local Dealer and they found one. Will have it here tomorrow.
$15.00 bucks aint bad!
Offline 4Cruizn
  • HEMI FISH
« Reply #9 on: May 27, 2004 - 06:11:57 PM »
BC here is a pic of the floor to filler tube seal.  This mounts to the 4 screw holes in your trunk floor! Also available at either of those 2 links!  If you need more pics, I'm installing the tank and filler tube in the near future.  Waiting for some j bolts for the tank mounting.
4C
« Last Edit: May 27, 2004 - 06:12:55 PM by 4cruzin »
« Reply #10 on: May 27, 2004 - 06:40:32 PM »
They are BEAUUUUUUUUUUTIFUL...... New parts always gets me in touch with my CUDA side.  :P
Offline 360 'CUDA
« Reply #11 on: May 27, 2004 - 07:20:09 PM »
Look out for little rubber chunks falling in the gas tank
when you take it out
« Reply #12 on: May 28, 2004 - 06:21:34 PM »
Cant I use a rubber magnet to keep it from doing that?
Just kidding!  :o ;D :P 8)
