I drove my Cuda last weekend and today I came out and looked under the car and saw about 4-5 drops of what seems like coolant on the garage floor. After doing some investigating it looks like it is coming from the seem between the passenger side head and block. It appears to only be toward the very front but on the side of the engine not the front of the engine.
This is not a big leak, if you look at the were the head gasket is it looks damp with a small film of where it looks like coolant might be slightly seeping out and I do mean very slightly.
So my questions are first, is this normal for a motor that was built 2 years ago and has 1000 mile on it, and occasionally gets spun up to 6500 thru the gears or is this something that is a major problem waiting to happen?
And second, is this something that I can fix by re-torquing down the head or am I looking at having to replace the head gasket?
The motor is a stroked 340 with stock iron 'x' heads and I believe felpro gaskets but not completely sure on that. Any advice here would be greatly appricated.
-Thanks
