Author Topic: Need help with broadcast sheet decoding  (Read 1734 times)
Offline resq302
« on: January 25, 2009 - 05:49:17 AM »
Can someone help me?  I am trying to decode my broadcast sheet and I am having some problems with some areas.  I bought the book by Jake Hare titled 1969-1974 Mopar Broadcast Sheet Decoder Manual and don't quite fully understand what is where and goes to what.  To start with the problems, our car is a early built 1970 chally convert (sched prod date of 9/28/69) which ends up being a Sunday to start off with.  Secondly, the broadcast sheet is on the 1969 E series and not the 1970 series and it is stamped about half a line up which makes it even harder to read.  Is there anyone that has a master list of codes or such that could help us decode this broadcast sheet?  Items such as idle and tire labels are both 77 on the build sheet yet the book has no listing for what code 77 is for both.  Any help would be greatly appreciated.
Thanks in advance,
Brian
Offline resq302
Re: Need help with broadcast sheet decoding
« Reply #1 on: January 27, 2009 - 08:17:42 AM »
Anyone?
Offline garrett007
« Reply #2 on: January 30, 2009 - 01:37:37 PM »
I had the same problem with mine.  I had to get a "F series 1970" broadcast sheet and change the numbers over to it.  The columns are slightly different between the E and F series.  Then I was able to decode it.
'68 Charger
'70 Challenger RT/SE (non-running)
'70 Challenger Deputy (non-running)
'1979 Macho W150
'96 Avenger - Gone
'05 Town & Country
'06 Charger R/T
Offline resq302
« Reply #3 on: January 30, 2009 - 05:57:32 PM »
I tried that.  Still had problems as the coding seems to be in 69 format.
Offline Canadian Cuda
« Reply #4 on: January 31, 2009 - 04:15:39 PM »
did that email i sent you help at all. it was the best i could do
Geoff
70 Cuda 440-4, auto, 8 3/4 sure-grip
Offline resq302
« Reply #5 on: January 31, 2009 - 06:22:34 PM »
Yes, some things did but still am wondering about the codes in the blank spots on the sheet. :clueless:
