After Changing mine, if you dont have any other holes on top of the firewall, I learned that you should just patch your old one. Changing that out will cause a lot of work. Drilling, cutting, welding, grinding, then sealing the seam between the cowl and firewall, through the vent holes is a main pain in the a$$. Plus you also have to cut off the mounts that hold the struts to the shock towers and the mounts for the inner fenders. Cut some small patches and start welding them in.
