72 cuda rallye dash tach problem
Author Topic: 72 cuda rallye dash tach problem  (Read 3525 times)
Offline cudaneil
  • Mopar or Nocar ?
« on: January 25, 2009 - 03:59:32 PM »
   Hello again guys,
                          My tach is working but is reading very low.  At idle it reads correct or very near, but when you rev the motor it only moves as far as  3000 rpm .
             Just as if its being lazy and cant be bothered !!!       :clueless:       Any ideas  ?
        :cheers:  Cudaneil
just one more job to do..................  (O----{|||}----O)
Re: 72 cuda rallye dash tach problem
« Reply #1 on: January 25, 2009 - 04:24:54 PM »
This is one I haven't heard before.   :screwy:
So you idle at 700-800 RPM? I assume you are driving the car when you are testing it, so it doesn't get above 3000 even when you floor it? It's possible it needs rebuilt if that is the case.
« Reply #2 on: January 25, 2009 - 11:21:05 PM »
the electronics were not very advanced in 69 , get the RTE circuit board & solder it in it will be far more accurate
Offline cudaneil
  • Mopar or Nocar ?
« Reply #3 on: January 26, 2009 - 04:06:02 AM »
    Hi, Can you tell me more about the RTE circuit board,and where can i get one from ?
                                      Thanks,   Cudaneil.            :england:
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #4 on: January 26, 2009 - 04:41:05 AM »
http://rt-eng.com/mediawiki/index.php/RTE_67-74_Tach_kit
 :thumbsup:
Go Fast & Have Fun...
Offline cudaneil
  • Mopar or Nocar ?
« Reply #5 on: January 26, 2009 - 08:12:09 AM »
 :thumbsup:
                            Many Thanks TDB.................... :2thumbs:         :cheers:   Cudaneil.
Offline 73EStroker
« Reply #6 on: January 26, 2009 - 10:47:25 PM »
Plus you need to purchase their tach excerciser to calibrate the tach $35. Unless you have a machine (like an oscilloscope) that outputs a square wave pulse at a known rate. Otherwise you will be revving the engine up and down for hours. The excerciser also (go figure) excercises the bearings by moving the needle up to full scale and back to idle. This frees the needle up. I excercised mine overnight.
Barry (Salmon Arm)
Offline cudaneil
  • Mopar or Nocar ?
« Reply #7 on: January 27, 2009 - 05:40:02 AM »
       Hi stroker,  Thanks for the info..............but i am getting worried about Rt-Engineering because i have bought and paid for an electronic dash voltage stabiliser from them
            through the website.   Cost  $60  and have had no reply from them !    so i emailed them and the email was returned saying " known spammer"
                                                   cheers.............a worried CUDANEIL   :eek7:
    • THE DODGE BOYS
« Reply #8 on: January 27, 2009 - 06:42:17 AM »
try calling them on the phone Apparently they have had problems in the past with that, From there site.
http://rt-eng.com/mediawiki/index.php/RTE:About
Here are some other alternate email addresses you can use in case you find that our main email address is not working (typically because of spam filters):
mailto:ggarner@arkansasusa.com
mailto:greg@rt-eng.com
mailto:funcarnut@gmail.com
Dash-worx, a division of
Real Time Engineering
19352 Hilton Rd.
Springdale, AR 72764
1-479-756-2757
1-479-756-3917 Fax
http://www.rt-eng.com
Offline cudaneil
  • Mopar or Nocar ?
« Reply #9 on: January 27, 2009 - 07:16:23 AM »
      OK thanks tdb.   :thumbsup:
Offline inviolet
« Reply #10 on: June 16, 2009 - 03:25:30 PM »
I have a 70 Cuda with a lazy tach too. Its a rally dash tach and its running off a MSD 6AL with a MSD Ignition 8920 tach adapter. At idel The tach shows the rpm fine, but when you rev up the motor the tach is lazy/delayed. I called MSD and they said one possible fix is too add a capacitor 0.01µF 1 k Volt between the MSD Ignition 8920 tach adapter and the tach.
Any one have a similar issue?
Offline Bills70
« Reply #11 on: June 16, 2009 - 03:57:39 PM »
I know that cudas and challengers are similar, I wonder if this would solve my problem!  I have the MSD street fire boxwith the tach adapter and the tach in my rally cluster doesnt work at all? It is also possible that the shop that installed the MSD screwed it up!
