Lowering blocks and longer ubolts are by far the easiest and fairly cheap.
if you only want an inch or two lower the no cost way is to flip the front shackles upside down. You will have to use a rat tail file to oval the stud holes, but it is a zero cost way to lower the car and no lowering blocks required.
