Author Topic: Lowering car..??  (Read 7304 times)
nivvy
Re: Lowering car..??
« Reply #30 on: January 28, 2009 - 05:29:29 PM »
....Wouldnt they have to pass some sort of SAFETY SPEC..?? have you heard of them breakin before..?
they are no good and crack all the time.....  :working:
speedway motors sells aluminums...... there are solid aluminums also...
nivvy
« Reply #31 on: January 28, 2009 - 05:31:58 PM »
http://www.allstar-performance.com/product.htm?prod=482
machine shop cost to cut my blocks were $60 for machining so about $90ish total....
Offline 666 the legend
« Reply #32 on: January 28, 2009 - 06:22:26 PM »
...Oh so the BLOCKS crack..??..I thought you were talkin bout the U-BOLTS...lol..
67 Camaro SS/RS 4 speed[ royal plum]
68 Chevy II [Nova YENKO Clone]
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
nivvy
« Reply #33 on: January 28, 2009 - 07:26:15 PM »
yes the blocks....  :working:
« Reply #34 on: January 29, 2009 - 07:32:55 AM »
No safety spec for these. I've broken several sets before. Since they are cast, they are very brittle.  I went with extruded aluminum since and have had no problems in street, drag, and oval track applications.
Offline CUDA JAS
  • vroooooom!
« Reply #35 on: January 29, 2009 - 08:20:39 AM »
If you are only after a 1 inch drop or so, why not go the no cost option of fliping the front spring hangers, as was mentioned before?
74 'cuda 360/727
Just call me a gearhead!
« Reply #36 on: January 29, 2009 - 04:38:25 PM »
..Tuh tell yah the truth..Im not sure what that means..?? ...
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
« Reply #37 on: January 29, 2009 - 08:38:46 PM »
the front spring hanger can be removed from the spring & bolted on the other way up & remountd ,lowering the car approx 1", the problem with this is the holes are closer together at the top so all 4 holes need to be moved in or ouyt slightly to mount it upside down
« Reply #38 on: January 29, 2009 - 11:39:54 PM »
...Gotcha....I didnt think there was anymore ROOM to go up any higher..But...Ill take  a look at it tomorrow....Seems easy enough...Thanks for clearin that up for me...
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
« Reply #39 on: January 30, 2009 - 02:29:03 AM »
you may have a heck of a time getting the front spring eye bolt out though generally they are siezed in place unless some one has had them out & or antisiezed them before re-installing them , often you have to cut the bolt off spread the hanger then press out the bushings , install new bushings & replace the bolts
Offline 72bluNblu
« Reply #40 on: January 30, 2009 - 04:43:20 AM »
If no one has been under there recently, you may also find the hanger bolts/studs frozen. When I replaced my rear springs I also had to buy new hangers, between the front eye bolt and the hanger bolts I could't re-use either hanger...
« Reply #41 on: January 30, 2009 - 01:04:29 PM »
..uh oh...?? seems that?? Goin the " FREEWAY " might cost me ALOT MORE time and a lil bit of money....
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
« Reply #42 on: January 30, 2009 - 01:26:31 PM »
nothing is easy on a 40 year old car
Offline Grancoupe
« Reply #43 on: January 30, 2009 - 03:35:16 PM »
I tried pointing out the "no cost" part of the flipped hanger solution a while ago.  :dunno: :clueless:
« Reply #44 on: January 30, 2009 - 06:24:46 PM »
..And now it seems it might be a PAIN in the ASS and actually cost me MORE MONEY...lol...But YES Ill give yah PROPS for the suggestion..
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
