Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Steering column removal
« previous
next »
Print
Pages: [
1
Author
Topic: Steering column removal (Read 803 times)
William H Meister
Jr. Member
And so it begins...
on:
January 26, 2009 - 04:37:28 PM »
I am in the process of removing the column on my 72' cuda.
Is there any trick to removing this pin and pulling the column?
Thanks
Bill
Logged
shawge
Full Member
Zoiks!!
Re: Steering column removal
Reply #1 on:
January 26, 2009 - 04:54:04 PM »
IIRC, it's a roll pin. I used a flat drift punch + hammer on mine.
Logged
- Jerry
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #2 on:
January 26, 2009 - 06:07:23 PM »
You definitely need a punch to get it out. The diameter is the same as the bolts holding down the valve covers.
I used an old valve cover bolt. Even after that, you will need a pry bar to get the shaft off the steering box.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
January 26, 2009 - 06:58:31 PM »
pin punch & I use a pickle fork to pry it up
Logged
William H Meister
Jr. Member
And so it begins...
Reply #4 on:
January 26, 2009 - 07:05:12 PM »
Thanks for the help, I'll try the bolt trick.
Bill
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
January 26, 2009 - 07:09:16 PM »
looks like the bushings for the clutch shaft are shot or missing
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
