Author Topic: 73 Charger Front End Rebuild  (Read 1306 times)
Offline bordin34
« on: January 27, 2009 - 04:28:41 PM »
Does this list look right for the rebuild of my Chargers front end?
2-Tie-Rod Adjusting Sleeve     Moog ES440S          C-Body Part
2-Inner Tie-Rod End              Spicer 4011049        C-Body
2-Outer Tie-Rod End              Spicer 4011047       C-Body
2-Upper Ball Joints                Moog K7262N         Threaded
2-Lower Ball Joints                Moog K719            Threaded
4-Cam Bolts                        Spicer 6161013
1-Pitman Arm                      Spicer 4501028
1-Idler Arm                         Spicer 4501032
2-LCA Bushings                    Spicer 5651028     Rubber, just in case I mess up the sleeve in the arm currently
Just Suspension
Poly Strut Rod Bushings
Poly Control Arm Bushings LCA's and UCA's  LCA's have no sleeve.
Does this seem complete?
Dan
« Last Edit: January 27, 2009 - 09:46:50 PM by bordin34 »
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline quapman
    • Auto-Grip on Facebook
Re: 73 Charger Front End Rebuild
« Reply #1 on: January 27, 2009 - 07:08:46 PM »
These guys can probably answer for sure. A lot of that stuff is same as e-body, but with the different control arms and stuff.........
http://wichargerguy.proboards101.com/
This is the BEST 3rd gen Charger site on the net.
Steve
« Reply #2 on: January 27, 2009 - 07:20:30 PM »
Do you have a sway bar? .. end links & sway bar bushings, how about torsion bar seals.
Offline bordin34
« Reply #3 on: January 27, 2009 - 07:42:53 PM »
I have a new sway bar and bushings that will go in. Figuring the part numbers are correct is this all I need beside torsion bar boots and seals.
