Author Topic: Problems With Keisler Install - Tranny Pics Added Friday Afternoon  (Read 6512 times)
Re: Problems With Keisler Install - Tranny Pics Added Friday Afternoon
« Reply #15 on: January 31, 2009 - 10:11:47 AM »
I can see a few stress cracks in your mounts so the mounts are old & the engine could be sitting slightly lower due to this but still not a lot lower
Offline IMNCARN82
  • LeDZeP
« Reply #16 on: January 31, 2009 - 10:57:49 AM »
  I had to notch my hump a tad to get it up in there. About as much as yours is. I'm in a good place for pics to help. But I have an RMS front end. I had to beat on the hump to get it up in there,Just a little though. Pass. side.     I don't have any spacers in.  :clueless:       Your oil pan doesn't look quite right. Might just be me.  That steering link bent? What is holding the engine up in the back without the tranny in?  It needs to be kept up.  I can take some pics for you.    Robert.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline dtedler
« Reply #17 on: February 02, 2009 - 08:56:32 AM »
I'm just throwing this out right now, but is the front of your engine together?  Meaning the water pump and fan.  You need to eye ball the relation to the radiator.  I bet the top of your fan is very close to the radiator face.  Another way is to place a small level on your intake manifold.  The small block intake are cut between 3 and 4 degrees from the factory and aftermarkets are 3.5 degree per information that I received from Edelbrock.
Offline KiwiChallenger
« Reply #18 on: February 05, 2009 - 10:33:37 PM »
It looks to me that the engine is leaning toward the passengers side of the car and this is rotating the trans the same way. This could be causing the shifter to be miss aligned in the shifter hole in the hump.
Offline 70RT/SE
  • I'm a llama!
« Reply #19 on: February 07, 2009 - 08:52:37 AM »
For reason small block Cuda's have fitment issues. Yours is the 3rd small block Cuda that I have read about with same type install issues.
Have you checked your engine location?
From the center of the crankshaft to the top of the K-frame the correct distance is 5-1/4".
The engine is also offset toward the passenger-side. Measure from the center of the crankshaft to each frame rail. The
difference should be 2-1/2".
I have a BB Challenger with Keisler. When I originallly installed my trans, I didn't use any spacers and had no clearence issues. Later I added the 1" space and had to clearence the passenger side  of the tunnel.
Offline 70 Challenger Conv.
  • Work in progress
« Reply #20 on: February 27, 2009 - 01:06:27 AM »
I'm having a lot of problems fitting the Tremec into my previously automatic 71 Cuda.  I needed a lot more vertical clearance in the right side of the tunnel than the template provided, and I'm having to notch my existing crossmember.  In addition to that, the shifter tower is not centered left-to-right in the opening in the hump.  It is hitting the right side of the opening.  I'm going to have to make an adapter plate to slide the boot/bezel over.  From the installs I've seen in magazines, and what I've read from other forum members that have done this swap, this does not seem normal.  The vertical clearance issue with the tunnel, yes.  Hitting the crossmember, no.  Definitely haven't heard anyone say the shift tower was off center in the hump opening, and I even purchased an original hump hoping to avoid repro issues.
Thoughts?
-Jeff
Any chance I could get a look at the template? Was it difficult to get make the changes? I am planning to install a tremec in my Challenger in the near future and would be interested in any advise you might have. Thanks  :working:  :wavingflag:
70 Convertible 572 Keith Black Aluminum Hemi ProFlow EFI 727 w/Gear Vendors OD added power door locks and power trunk release and keyless entry Rack and Pinion power steering... future change to 6 speed manual tranny
