Author Topic: Camber Change with Ride Height  (Read 679 times)
Offline LAA66
« on: January 28, 2009 - 11:16:20 AM »
 Just had the front end aligned, set at -.5 degrees camber and now want to raise the front a little bit. Curious how much changing the front end height say 1" would affect the camber (or even toe for that matter). Caster is maxed out at 3.5 pos.
Re: Camber Change with Ride Height
« Reply #1 on: January 28, 2009 - 01:06:49 PM »
everything affects everything , you will probably lose a bit of camber & toe will change how much depends how much you raise it up
Offline LAA66
« Reply #2 on: January 28, 2009 - 10:22:15 PM »
  The front end settled between the garage and the alignment shop round trip and lost about 1/2" from what looked right to me. I just installed all new components and can only guess they hadn't seated in yet.
 It does have a pull, and the steering wheel is just a bit off center, so I planned to take it back to the shop anyways. I will reset the height before that. :working: Thanks for the response CP.
