Fuel line setup on a 1970 R/T 383/440
Author Topic: Fuel line setup on a 1970 R/T 383/440  (Read 882 times)
Offline Oz-E-Body
  • It's Alive!!
« on: January 28, 2009 - 12:34:07 PM »
Hi all, I was wondering if someone can tell me how the fuel lines are supposed to run on my R/T 383. There seems to be several lines or breathers that congregate in the trunk near the fuel filler and I have two lines than run up the chassis rail to the engine bay.
So I am wondering what the second line into the engine bay would have been used for? And is it safe/o.k to plug this second line as I don’t intend to use it?
Keep in mind I am now running a warmed over 440 with a new Holley 750 4 barrel with no pollution/smog gear on the carb.
Thanks
Re: Fuel line setup on a 1970 R/T 383/440
« Reply #1 on: January 28, 2009 - 01:15:21 PM »
the small line from the tank was to return fuel from the vapor seperator above the fuel pump , it can be left off or blocked if you do not have the seperator in place
Offline Oz-E-Body
  • It's Alive!!
« Reply #2 on: January 31, 2009 - 05:46:33 PM »
Thanks for your reply C/P, I think the two lines in question are the same size?.
I’ll do another check measure and then block one of them off.
Thanks again..
« Reply #3 on: February 01, 2009 - 02:46:33 AM »
if you have 2 usually one is 3/8" the other is 1/4
